Always be ready to play and stay organised with this all-in-one wireless charging dock for the Meta Quest 3 headset and controllers. Includes high-capacity, lithium-ion rechargeable batteries for your controllers so you can simply drop in your headset and controllers for wireless charging. While powering up your gear, the dock also displays your devices in style and within easy reach. This genuine Meta accessory ensures quality and a perfect fit and is compatible with our other accessories including Elite Strap, Elite Strap with Battery, and Active Straps (sold separately).
 - Meta charging dock - with battery - 2 - Li-Ion
- Product Type
 - Charging dock + battery
 - 8.912 cm x 32.368 cm x 6.432 cm
 - 427 g
 - White
- Output Connector Type
 - On cable: USB-C
- Battery
 - Lithium Ion - 167 mAh - 0.64 Wh
- Cables
 - USB-C cable - 2 m
- Batteries Included
 - 2 pcs.
- Designed For
 - Meta Quest 3
- Product Type
 - Charging dock battery
- Designed For
 - Virtual reality headset, virtual reality headset controller
 - 8.912 cm
 - 32.368 cm
 - 6.432 cm
 - 427 g
- Enclosure Colour
 - White
- Detachable Cable Connector Type
 - USB-C
 - Charging LED indication, overheat protection
- Compatible Game Consoles
 - Meta Quest 3
- Technology
 - Lithium Ion
- Included Qty
 - 2
- Voltage Provided
 - 3.85 V
- Capacity
 - 167 mAh - 0.64 Wh
- Cables Included
 - USB-C cable - 2 m
- Designed For
 - Meta Quest 3
