Meta Quest 3 Carry Case
Quicklinx: HDW0BTBS Mfr#: 899-00588-01
Type: Case
£58.33 ex VAT
£69.99 inc VAT
Take your headset and accessories on the go with style and protection. Designed to fit your headset, Touch Plus controllers, charging cable, adapter, head strap (standard or Elite) and Active Straps, this case features an outer felt shell and contoured inner compartments to keep your gear organised and secure. With its lightweight construction, soft hand strap, zip opening and rounded profile, the case makes it easy to carry and access your Meta Quest 3 and accessories on the go. This genuine Meta Quest accessory ensures a perfect fit, durability and convenience for your VR setup.
Meta - case for virtual reality headset
Case for virtual reality headset
24.18 cm x 32.83 cm x 12.8 cm
674 g
Material
Felt
Light grey
Meta Quest 3
24.18 cm
32.83 cm
12.8 cm
674 g
Material
Felt
Light grey
Carrying Case
Case
Recommended Use
For virtual reality headset
Closure Type
Zipper
Lightweight
Limited warranty - 1 year
Meta Quest 3
Type: Case
Brand: Meta
