Meta Quest 3 Active Straps
Quicklinx: HDW2WS00 Mfr#: 899-00589-01
Hurry, only 3 left in stock!
£33.33 ex VAT
£39.99 inc VAT
Play with confidence and intensity with these adjustable straps that give you extra grip and stability for your Meta Quest Touch Plus Controllers. Active Straps fit most hand sizes and can be worn comfortably even for long sessions, with their breathable woven nylon straps and hook-and-loop fasteners. These genuine straps for Meta Quest Touch Plus Controllers give you peace of mind as you play, navigate and gesture in VR without the risk of losing your grip.
  • Play with confidence
    These straps give you peace of mind as you play, navigate, and gesture in VR without the risk of losing your grip.
  • Comfort and security
    fit most hand sizes and can be worn comfortably even for long sessions, with their breathable woven nylon straps and hook and loop fasteners. The straps ensure an excellent tracking experience, letting you move with confidence and uninterrupted immersion. Designed for intense and frequent use.
Meta Quest game controller hand strap
Game controller hand strap
Packaged Quantity
2 (specifications are for single item)
Product Material
Plastic, metal, woven nylon
2 cm
Length
29 cm
27.3 g
Slate black
1-year warranty
Packaged Quantity
Product Material
2 cm
Length
29 cm
27.3 g
Slate black
Hook & loop fastener
Limited warranty - 1 year
Type: Controller Strap
Brand: Meta
