Play with confidence and intensity with these adjustable straps that give you extra grip and stability for your Meta Quest Touch Plus Controllers. Active Straps fit most hand sizes and can be worn comfortably even for long sessions, with their breathable woven nylon straps and hook-and-loop fasteners. These genuine straps for Meta Quest Touch Plus Controllers give you peace of mind as you play, navigate and gesture in VR without the risk of losing your grip.
These straps give you peace of mind as you play, navigate, and gesture in VR without the risk of losing your grip. -
Comfort and security
fit most hand sizes and can be worn comfortably even for long sessions, with their breathable woven nylon straps and hook and loop fasteners. The straps ensure an excellent tracking experience, letting you move with confidence and uninterrupted immersion. Designed for intense and frequent use.
- Meta Quest game controller hand strap
- Product Type
- Game controller hand strap
- Packaged Quantity
- 2 (specifications are for single item)
- Product Material
- Plastic, metal, woven nylon
- 2 cm
- Length
- 29 cm
- 27.3 g
- Slate black
- 1-year warranty
- Packaged Quantity
- Product Type
- Product Material
- 2 cm
- Length
- 29 cm
- 27.3 g
- Slate black
- Hook & loop fastener
- Limited warranty - 1 year
