Meta Quest 2 Link Cable
Quicklinx: GYP1WS00 Mfr#: 301-00311-01
Type: Cable
£70.83 ex VAT
£84.99 inc VAT
Play the best of both worlds with Oculus Link high-speed fiber optic cable that connects your compatible gaming PC to the all-in-one Oculus Quest headset. Its lightweight, flexible design empowers you to take on a wide range of games from the action-packed Oculus Rift library.
Expand your library
Connect to over 1,000 PC-based VR titles in the Rift library.
Move with freedom
This ultra-long, ultra-fast, flexible fibre-optic cable is designed for VR.
Meta Link - virtual reality headset cable - 24 pin USB-C to 24 pin USB-C - 5 m
Virtual reality headset cable
Double shielded/fibre optic
5 Gbps data rate
Length
5 m
Connector
24 pin USB-C - male - right-angled
Connector (Second End)
24 pin USB-C - male - straight
Rated Current
3 A
USB 3.2 Gen 1
Meta Quest, Quest 2, Quest 2 (128 GB), Quest 2 (256 GB), Quest 2 (64 GB), Quest 3, Quest 3 (128 GB), Quest 3 (512 GB), Quest 3S, Quest 3S (128 GB), Quest 3S (256 GB), Quest Pro
Jacket Material
Thermoplastic polyurethane
Rated Current
3 A
5 Gbps data rate
Length
5 m
Outside Diameter
4.6 mm
224 g
Connector
USB 3.2 Gen 1
Type: Cable
Brand: Meta
