Play the best of both worlds with Oculus Link high-speed fiber optic cable that connects your compatible gaming PC to the all-in-one Oculus Quest headset. Its lightweight, flexible design empowers you to take on a wide range of games from the action-packed Oculus Rift library.
Expand your library
Connect to over 1,000 PC-based VR titles in the Rift library.
Move with freedom
This ultra-long, ultra-fast, flexible fibre-optic cable is designed for VR.
 - Meta Link - virtual reality headset cable - 24 pin USB-C to 24 pin USB-C - 5 m
 - Virtual reality headset cable
- Technology
 - Double shielded/fibre optic
 - 5 Gbps data rate
- Length
 - 5 m
- Connector
 - 24 pin USB-C - male - right-angled
- Connector (Second End)
 - 24 pin USB-C - male - straight
- Rated Current
 - 3 A
 - USB 3.2 Gen 1
 - Black
- Designed For
 - Meta Quest, Quest 2, Quest 2 (128 GB), Quest 2 (256 GB), Quest 2 (64 GB), Quest 3, Quest 3 (128 GB), Quest 3 (512 GB), Quest 3S, Quest 3S (128 GB), Quest 3S (256 GB), Quest Pro
- Technology
- Jacket Material
 - Thermoplastic polyurethane
- Rated Current
 - 3 A
 - 5 Gbps data rate
- Length
 - 5 m
- Outside Diameter
 - 4.6 mm
 - Black
 - 224 g
- Connector
 - USB 3.2 Gen 1
- Designed For
