Go all in with enhanced comfort and battery life. This ergonomic strap increases balance and support with a quick twist of the fit wheel. The built-in battery doubles your playtime, letting you stay focused from the first step to the final mission.
Extend your play time
A built-in battery extends your play time between charges.
Maximise your comfort
A balancing design uses battery weight to lift the headset away from your face for a lighter feel.
Seamless compatibility
Engineered for use with official Meta Quest hardware and accessories (sold separately).
                Enhanced comfortDesigned specifically for extended gaming sessions, this virtual reality headset strap offers comfort, allowing you to immerse yourself in virtual worlds without the distraction of discomfort.
                Easy integrationSeamlessly integrates with your existing Meta virtual reality headset, ensuring a perfect fit and an enhanced virtual reality experience without the need for additional tools or complicated setup procedures.
- Meta virtual reality headset strap
- Product Type
- Virtual reality headset strap
- 20 cm x 12 cm x 37 cm
- 179 g
- Designed For
- Meta Quest 2, Quest 2 (128 GB), Quest 2 (256 GB), Quest 2 (64 GB)
- Product Type
- 20 cm - 12 cm - 37 cm
- 179 g
- Shipping Dimensions (WxDxH) / Weight
- 29.4 cm x 20.1 cm x 12.4 cm
- Designed For
