Upgrade your comfort and secure your headset in the perfect position for the clearest visuals, however much you move.
Enhance your comfort
Straps, bracing and an easily adjustable fit wheel work together for the perfect fit.
Stay in the sweet spot
Keep your headset in the right position for the best visuals, even as you move.
- Meta virtual reality headset strap
- Product Type
- Virtual reality headset strap
- 17.5 cm x 21.5 cm x 10.4 cm
- 179 g
- Designed For
- Meta Quest 2 (256 GB), Quest 2 (64 GB); Oculus Quest 2, Quest 2 (256 GB)
- Product Type
- 17.5 cm - 21.5 cm - 10.4 cm
- 179 g
- Shipping Dimensions (WxDxH) / Weight
- 20.1 cm x 29.4 cm x 12.4 cm
- Designed For
- Meta Quest 2 (256 GB), Quest 2 (64 GB) , Oculus Quest 2, Quest 2 (256 GB)
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
GYP3 048590 Condition: Customer return - item has been opened but is in excellent condition |
£15.62 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
