Meta Quest 2 Carry Case
Quicklinx: GYP2WS00 Mfr#: 301-00369-01
Type: Case
More than 50 In Stock
£33.33 ex VAT
£39.99 inc VAT
Express delivery Order within the next 53 minutes for delivery tomorrow
Bring it with you or tuck it away. This lightweight case provides sturdy protection whether you're at home or on the go. The padded interior fits the Oculus Quest 2 headset.
Everything in its place
The Quest 2 Carrying Case fits your headset, two controllers, a charge cable, power adaptor and either Elite Strap perfectly.
Safe storage
A dual shell outer casing keeps your Quest 2 system out of harm’s way.
Portable protection
Contoured foam inner moulding absorbs rattles and bumps as you travel.
Meta Quest - case for virtual reality headset
Case for virtual reality headset
Meta Quest 2 (256 GB), Quest 2 (64 GB)
Carrying Case
Case
Recommended Use
For virtual reality headset
Type: Case
Brand: Meta
