For ages 10+ only. Requires mobile device, wifi and companion app for setup. Account registration required
Resolution
Experience lifelike visuals with a resolution of 1832 x 1920 per eye, making interactions in the virtual world feel more real and engaging. -
Comfortable design
The adjustable headband allows users to customize their fit, providing comfort during extended sessions and enhancing overall usability. -
Versatile audio options
Choose between the built-in speakers for a surround sound experience or connect headphones for more personal audio, catering to different user preferences. -
Seamless connectivity
Utilizing USB-C for both input and output makes it easy to connect to various devices, ensuring a smooth transition between gaming and multimedia.
- Meta Quest 2 (256 GB) - virtual reality system
- Virtual reality system
- Sensors
- Motion sensor
- Resolution per Eye
- 1832 x 1920
- Input Connectors
- USB-C
- Localisation
- United Kingdom
- Display Type
- Configuration
- Qualcomm Snapdragon XR2, 6 GB RAM, 256 GB ROM
VR Headset
- 1832 x 1920
- Sensors
- Motion sensor
- Adjustable headband, 6DoF Tracking Architecture
Audio
- Speakers - stereo
- Headphones (mini-jack) , USB-C
- Included Accessories
- Eyeglass spacer, 2 touch controllers, 2 x AA batteries, charging cable, power adapter
- Localisation
- United Kingdom
- Return - 30 days
Meta Quest 2 Link Cable | In Stock | £70.83 |
Meta Quest 2 Fit Pack | In Stock | £16.66 |
