Meta Open Facial Interface - Quest 3/3S
Quicklinx: HVPBWS00 Mfr#: SK-1000040-01
More than 50 In Stock
£5.41 ex VAT
£6.49 inc VAT
Marketing description is not available.
  • Comfortable Fit
    The foam material used in this face interface provides a comfortable fit that conforms to the contours of the face, reducing strain during long virtual reality sessions.
  • Easy Maintenance
    Featuring a washable design, this face interface allows for easy cleaning, ensuring that it remains fresh and hygienic after each use.
Meta virtual reality headset face interface - open
Virtual reality headset face interface
Product Material
Polyester, foam
10.6 cm x 16 cm x 9.8 cm
60 g
Meta Quest 3, Quest 3S
Product Material
Polyester, foam
10.6 cm - 16 cm - 9.8 cm
60 g
Washable
