Meraki Wide Angle MV12 Mini Dome HD Camera With 128GB Storage
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVQS
Quicklinx: DV92WS00 Mfr#: MV12WE-HW
£435.41 ex VAT
£522.49 inc VAT
Compact dome camera for indoor security: cloud management, reliable edge storage, and advanced analytics.
  • Wide angle coverage
    Equipped with a lens that offers a 114° horizontal and 61° vertical field of view, the Wide Angle MV12 Mini Dome HD Camera ensures comprehensive coverage of your space, making it ideal for monitoring wide areas with fewer cameras.
  • High-definition video
    With the capability to capture video in resolutions up to 2688 x 1520, this camera delivers crisp, clear high-definition footage, ensuring that no detail goes unnoticed.
  • Versatile connectivity
    Featuring Ethernet 10Base-T/100Base-TX/1000Base-T network interface with RJ-45 connector for LAN/power, this camera offers flexible installation options and easy integration into your existing network infrastructure.
  • Advanced night vision
    Infrared LEDs provide clear night vision up to 15 m, allowing for reliable surveillance in low-light conditions or complete darkness.
  • Durable design
    Designed to operate in a wide range of environmental conditions, with operating temperatures from 0°C to 40°C and compliance with IEEE 802.3af standards, this camera is built to withstand the demands of continuous surveillance.
Cisco Meraki Wide Angle MV12 Mini Dome HD Camera - network surveillance camera - dome
Network surveillance camera - fixed - dome
Audio
Camera Mount Type
Wall mount
10.6 cm x 10.6 cm x 7.4 cm
286 g
Wired
Camera
Colour - Day&Night
Max Resolution
2688 x 1520
Video Modes
1080p
Optical Sensor Type
CMOS - 1/3" - 4 MP
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Focus Adjustment
Manual
Lens Iris
F/1.8
Voltage
PoE
LED indicator, reset button, remote focus
3-year warranty
Environmental Parameters (operating)
0 °C - 40 °C
Audio Support
Dome
Camera Mount Type
Wall mount
Wired
10.6 cm
10.6 cm
7.4 cm
286 g
Camera
Colour - Day&Night - fixed
Digital Video Format
H.264
Max Digital Video Resolution
2688 x 1520
Video Modes
1080p
Exposure Range
1/30 sec - 1/32000 sec
Infrared LEDs
Infrared Distance
15 m
Digital Video Capture Resolution
1920 x 1080, 2688 x 1520
Flash Memory
128 GB
Image Sensor
4 MP CMOS 1/3"
Lens Construction
Fixed focal
Focal Length
2.8 mm
Lens Iris
F/1.8
Focus Adjustment
Manual
Horizontal Field of View (degree)
114
Vertical Field of View (degree)
61
Network Interface
Network Protocols
TLS, DSCP
Ports
LAN/power - RJ-45
Wall mount kit
Plug and Play, IEEE 802.3af
Power Requirements
PoE
12.95 Watt
Limited warranty - advance parts replacement - 3 years
Brand: Meraki
