Compact dome camera for indoor security: cloud management, reliable edge storage, and advanced analytics.
Wide angle coverage
Equipped with a lens that offers a 114° horizontal and 61° vertical field of view, the Wide Angle MV12 Mini Dome HD Camera ensures comprehensive coverage of your space, making it ideal for monitoring wide areas with fewer cameras. -
High-definition video
With the capability to capture video in resolutions up to 2688 x 1520, this camera delivers crisp, clear high-definition footage, ensuring that no detail goes unnoticed. -
Versatile connectivity
Featuring Ethernet 10Base-T/100Base-TX/1000Base-T network interface with RJ-45 connector for LAN/power, this camera offers flexible installation options and easy integration into your existing network infrastructure. -
Advanced night vision
Infrared LEDs provide clear night vision up to 15 m, allowing for reliable surveillance in low-light conditions or complete darkness. -
Durable design
Designed to operate in a wide range of environmental conditions, with operating temperatures from 0°C to 40°C and compliance with IEEE 802.3af standards, this camera is built to withstand the demands of continuous surveillance.
- Cisco Meraki Wide Angle MV12 Mini Dome HD Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome
- Audio
- Camera Mount Type
- Wall mount
- 10.6 cm x 10.6 cm x 7.4 cm
- 286 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 2688 x 1520
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/3" - 4 MP
- Focal Length Control
- Fixed focal
- Focal Length
- 2.8 mm
- Focus Adjustment
- Manual
- Lens Iris
- F/1.8
- Ethernet 10Base-T/100Base-TX/1000Base-T
- Voltage
- PoE
- LED indicator, reset button, remote focus
- 3-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C
- Audio Support
- Form Factor
- Dome
- Camera Mount Type
- Wall mount
- Wired
- 10.6 cm
- 10.6 cm
- 7.4 cm
- 286 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 2688 x 1520
- Video Modes
- 1080p
- Exposure Range
- 1/30 sec - 1/32000 sec
- Infrared LEDs
- Infrared Distance
- 15 m
- Digital Video Capture Resolution
- 1920 x 1080, 2688 x 1520
- Flash Memory
- 128 GB
Image Sensor
- 4 MP CMOS 1/3"
Lens Construction
- Fixed focal
- Focal Length
- 2.8 mm
- Lens Iris
- F/1.8
- Focus Adjustment
- Manual
- Horizontal Field of View (degree)
- 114
- Vertical Field of View (degree)
- 61
- Network Interface
- Network Protocols
- TLS, DSCP
- Ports
- LAN/power - RJ-45
- Included Accessories
- Wall mount kit
- Plug and Play, IEEE 802.3af
- Power Requirements
- PoE
- Power Device
- 12.95 watt
- Limited warranty - advance parts replacement - 3 years
- 0 °C
- 40 °C
