Compact dome camera for indoor security: cloud management, reliable edge storage, and advanced analytics.
Robust environmental adaptability
Designed to operate seamlessly in conditions ranging from 0°C to 40°C, the Narrow Angle MV12 Mini Dome HD Camera ensures reliable performance in a wide range of environmental settings. Its ability to withstand diverse temperatures makes it an ideal choice for various locations, enhancing its versatility and utility. -
High-definition imaging
Equipped with a CMOS optical sensor and a lens aperture of f/1.8, this camera captures high-quality images with a total pixel count of 4,000,000. The fixed focal lens, with a minimum focal length of 3.8 mm, provides clear and detailed visuals, ensuring critical moments are captured with clarity. -
Advanced connectivity options
Featuring Ethernet 10Base-T/100Base-TX/1000Base-T network interface and support for key network protocols like DSCP and TLS, alongside Wi-Fi connectivity, this camera offers flexible and secure options for integrating into existing networks. Its RJ-45 connector for LAN/power simplifies installation and maintenance. -
Enhanced night vision capability
With infrared LEDs and a maximum infrared distance of 15 m, the camera provides exceptional night vision. This feature, combined with day and night functionality, ensures continuous surveillance and security, capturing high-quality footage around the clock. -
Efficient power management
The camera's low voltage power requirement, supported by PoE (Power over Ethernet), along with an operational power consumption of just 12.95 watts, makes it an energy-efficient choice for continuous surveillance operations. This feature not only reduces running costs but also supports a greener operation.
- Cisco Meraki Narrow Angle MV12 Mini Dome HD Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome
- Audio
- Camera Mount Type
- Wall mount
- 10.6 cm x 10.6 cm x 7.4 cm
- 286 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 2688 x 1520
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/3" - 4 MP
- Focal Length Control
- Fixed focal
- Focal Length
- 3.8 mm
- Focus Adjustment
- Manual
- Lens Iris
- F/1.8
- Ethernet 10Base-T/100Base-TX/1000Base-T
- Voltage
- PoE
- LED indicator, reset button, remote focus
- 3-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C
- Audio Support
- Form Factor
- Dome
- Camera Mount Type
- Wall mount
- Wired
- 10.6 cm
- 10.6 cm
- 7.4 cm
- 286 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 2688 x 1520
- Video Modes
- 1080p
- Exposure Range
- 1/30 sec - 1/32000 sec
- Infrared LEDs
- Infrared Distance
- 15 m
- Digital Video Capture Resolution
- 1920 x 1080, 2688 x 1520
- Flash Memory
- 256 GB
Image Sensor
- 4 MP CMOS 1/3"
Lens Construction
- Fixed focal
- Focal Length
- 3.8 mm
- Lens Iris
- F/1.8
- Focus Adjustment
- Manual
- Horizontal Field of View (degree)
- 73
- Vertical Field of View (degree)
- 44
- Network Interface
- Network Protocols
- TLS, DSCP
- Ports
- LAN/power - RJ-45
- Included Accessories
- Wall mount kit
- Plug and Play, IEEE 802.3af
- Power Requirements
- PoE
- Power Device
- 12.95 Watt
- Limited warranty - advance parts replacement - 3 years
- 0 °C
- 40 °C
