Meraki Narrow Angle MV12 Mini Dome HD Camera With 256GB Storage
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVQS
Quicklinx: DV90WS00 Mfr#: MV12N-HW
£486.51 ex VAT
£583.81 inc VAT
Compact dome camera for indoor security: cloud management, reliable edge storage, and advanced analytics.
  • Robust environmental adaptability
    Designed to operate seamlessly in conditions ranging from 0°C to 40°C, the Narrow Angle MV12 Mini Dome HD Camera ensures reliable performance in a wide range of environmental settings. Its ability to withstand diverse temperatures makes it an ideal choice for various locations, enhancing its versatility and utility.
  • High-definition imaging
    Equipped with a CMOS optical sensor and a lens aperture of f/1.8, this camera captures high-quality images with a total pixel count of 4,000,000. The fixed focal lens, with a minimum focal length of 3.8 mm, provides clear and detailed visuals, ensuring critical moments are captured with clarity.
  • Advanced connectivity options
    Featuring Ethernet 10Base-T/100Base-TX/1000Base-T network interface and support for key network protocols like DSCP and TLS, alongside Wi-Fi connectivity, this camera offers flexible and secure options for integrating into existing networks. Its RJ-45 connector for LAN/power simplifies installation and maintenance.
  • Enhanced night vision capability
    With infrared LEDs and a maximum infrared distance of 15 m, the camera provides exceptional night vision. This feature, combined with day and night functionality, ensures continuous surveillance and security, capturing high-quality footage around the clock.
  • Efficient power management
    The camera's low voltage power requirement, supported by PoE (Power over Ethernet), along with an operational power consumption of just 12.95 watts, makes it an energy-efficient choice for continuous surveillance operations. This feature not only reduces running costs but also supports a greener operation.
Cisco Meraki Narrow Angle MV12 Mini Dome HD Camera - network surveillance camera - dome
Network surveillance camera - fixed - dome
Audio
Camera Mount Type
Wall mount
10.6 cm x 10.6 cm x 7.4 cm
286 g
Wired
Camera
Colour - Day&Night
Max Resolution
2688 x 1520
Video Modes
1080p
Optical Sensor Type
CMOS - 1/3" - 4 MP
Focal Length Control
Fixed focal
Focal Length
3.8 mm
Focus Adjustment
Manual
Lens Iris
F/1.8
Voltage
PoE
LED indicator, reset button, remote focus
3-year warranty
Environmental Parameters (operating)
0 °C - 40 °C
Audio Support
Dome
Camera Mount Type
Wall mount
Wired
10.6 cm
10.6 cm
7.4 cm
286 g
Camera
Colour - Day&Night - fixed
Digital Video Format
H.264
Max Digital Video Resolution
2688 x 1520
Video Modes
1080p
Exposure Range
1/30 sec - 1/32000 sec
Infrared LEDs
Infrared Distance
15 m
Digital Video Capture Resolution
1920 x 1080, 2688 x 1520
Flash Memory
256 GB
Image Sensor
4 MP CMOS 1/3"
Lens Construction
Fixed focal
Focal Length
3.8 mm
Lens Iris
F/1.8
Focus Adjustment
Manual
Horizontal Field of View (degree)
73
Vertical Field of View (degree)
44
Network Interface
Network Protocols
TLS, DSCP
Ports
LAN/power - RJ-45
Wall mount kit
Plug and Play, IEEE 802.3af
Power Requirements
PoE
12.95 watt
Limited warranty - advance parts replacement - 3 years
Brand: Meraki
