Meraki MX68W Router
Meraki MX68W Router
REQUIRES LICENCE. CONTACT OUR IT SPECIALISTS: 0370 429 3010
Quicklinx: DZPKWS00 Mfr#: MX68W-HW
Type: Security appliance
Standards: Ethernet, IEEE 802.11g, Gigabit Ethernet, IEEE 802.11n + 4 more
Speed: 1.3Gbps
Rackmount or External: Desktop
  • IEEE 802.11n
20 In Stock
£539.74 ex VAT
£647.68 inc VAT
Lockdown your network with the Cisco Meraki MX68W cloud-managed security & SD-WAN appliance that has 802.11ac Wave 2 Wi-Fi. Ideal for small retail branches or clinics, this device can routinely support up to 50 users and has a stateful firewall throughput of up to 450 Mbps. It allows a maximum of 50 simultaneous VPN sessions for absolutely secure data transfer and includes five Gigabit Ethernet interfaces so that you can connect a variety of devices to it.
Since the MX is 100% cloud managed, installation and remote management is simple. The MX has a comprehensive suite of security and network services including threat management and SD-WAN capabilities, eliminating the need for multiple appliances. Your business can use a central location to set up its retail outlets or clinics without having to travel. Template-based multi-network management allows you to quickly set up profiles and settings across thousands of devices to ensure it scales easily. Monitoring and reporting systems ensure you get email alerts that inform you of utilization metrics, and comprehensive changelogs make tracing modifications very quick.
Quickly secure your network with the intelligent WAN that includes policy-based routing and dynamic VPN path selection, and it has a variety of application-layer protocols and systems that ensure only authorized visitors get in. Threat management solutions include content filtering, intrusion prevention using a PCI-compliant IPS sensor, identity-based policies, and Advanced Malware Protection from Cisco for maximum protection. An enhanced CPU and plenty of memory ensure this Cisco Meraki cloud-managed security & SD-WAN appliance can process all the information flowing through it rapidly.
The MX68W also includes 12 ports, including 2 GbE RJ45 WAN interfaces, 10 GbE RJ45 LAN interfaces, and 2 PoE+ for downstream access points and switches.
  • Enhanced connectivity
    With dual-band Wi-Fi 5 and a suite of Ethernet, USB, and PoE+ ports, the Cisco Meraki MX68W offers versatile connectivity options for a wide range of devices and applications.
  • Robust security
    Equipped with advanced security features such as firewall protection, IPSec VPN support, and intrusion prevention systems, this security appliance ensures your network remains secure against threats.
  • High performance
    Achieve up to 450 Mbps firewall throughput and 200 Mbps VPN throughput, alongside 300 Mbps advanced security throughput, ensuring efficient and secure data flow across your network.
  • Comprehensive network management
    Features like DHCP support, NAT support, and static routing facilitate seamless network management, while quality of service (QoS) prioritizes critical network traffic.
  • Flexible installation
    The desktop form factor with wall-mountable option provides flexibility in deployment, making it suitable for various environments.
Cisco Meraki MX68W - security appliance - Wi-Fi 5
Security appliance
Desktop
Ports Qty
10
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Firewall throughput: 450 Mbps , VPN throughput: 200 Mbps , Advanced security throughput: 300 Mbps
Maximum number of users: 50 , Maximum number of configured SSIDs: 4
Mobile Communication Protocol
LTE
Power Over Ethernet (PoE) Supported
PoE+
28.4 cm x 17.8 cm x 2.7 cm
1.18 kg
Security appliance
Built-in Devices
Modem
28.4 cm
17.8 cm
2.7 cm
1.18 kg
Desktop
Ports Qty
10
Wireless, wired
Data Transfer Rate
1.3 Gbps
Network / Transport Protocol
L2TP, IPSec, PPPoE, DHCP
Routing Protocol
Static IP routing, MPLS
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz, 5 GHz
Performance
Firewall protection, DHCP support, NAT support, load balancing, layer 7 switching, VLAN support, traffic shaping, content filtering, Intrusion Detection System (IDS), Intrusion Prevention System (IPS), firmware upgradable, wall mountable, IPSec Virtual Private Network (VPN), Quality of Service (QoS), MPLS VPN, 3G/4G USB Dongle Support, static routing, 802.1x authentication, Link Aggregation, VPN client, IP Security (IPSec) support, DMZ support
Encryption Algorithm
WPA, WPA-PSK, WPA2-Enterprise, WEP
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
2
Directivity
Omni-directional
Communications
LTE
2 x 1000Base-T - RJ-45 (WAN) , 8 x 1000Base-T - RJ-45 , 2 x 1000Base-T (PoE+) - RJ-45 , 1 x USB 2.0 - Type A , 2 x aerial - RP-SMA
C-Tick, CB, IC, FCC, RoHS, CISPR, IPsec/IKE
PoE+
External power adapter
Installed Qty
1
Max Supported Qty
1
89 Watt
Power Provided
100 Watt
Limited warranty - advance hardware replacement - lifetime - response time: next day
5 - 95%
Standards: Ethernet
Standards: IEEE 802.11g
Standards: Gigabit Ethernet
Standards: IEEE 802.11n
Standards: IEEE 802.11a
Standards: Fast Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11ac
Speed: 1.3Gbps
Brand: Meraki
Price Range Ex VAT: £500 - £750
