Meraki MX68 Router
Meraki MX68 Router
REQUIRES LICENCE. CONTACT OUR IT SPECIALISTS: 0370 429 3010
Quicklinx: DZPJWS00 Mfr#: MX68-HW
Type: Security appliance
Standards: Gigabit Ethernet, Ethernet, Fast Ethernet
Rackmount or External: Desktop
More than 50 In Stock
£404.60 ex VAT
£485.52 inc VAT
Lockdown your network with the Cisco Meraki MX68 cloud-managed security & SD-WAN appliance. Ideal for small retail branches or clinics, this device can routinely support up to 50 users and has a stateful firewall throughput of up to 450 Mbps. It allows a maximum of 50 simultaneous VPN sessions for absolutely secure data transfer and includes five Gigabit Ethernet interfaces so that you can connect a variety of devices to it.
Since the MX is 100% cloud managed, installation and remote management is simple. The MX has a comprehensive suite of security and network services including threat management and SD-WAN capabilities, eliminating the need for multiple appliances. Your business can use a central location to set up its retail outlets or clinics without having to travel. Template-based multi-network management allows you to quickly set up profiles and settings across thousands of devices to ensure it scales easily. Monitoring and reporting systems ensure you get email alerts that inform you of utilization metrics, and comprehensive changelogs make tracing modifications very quick.
Quickly secure your network with the intelligent WAN that includes policy-based routing and dynamic VPN path selection, and it has a variety of application-layer protocols and systems that ensure only authorized visitors get in. Threat management solutions include content filtering, intrusion prevention using a PCI-compliant IPS sensor, identity-based policies, and Advanced Malware Protection from Cisco for maximum protection. An enhanced CPU and plenty of memory ensure this Cisco Meraki cloud-managed security & SD-WAN appliance can process all the information flowing through it rapidly.
The MX68 also includes 12 ports, including 2 GbE RJ45 WAN interfaces, 10 GbE RJ45 LAN interfaces, and 2 PoE+ for downstream access points and switches.
  • Robust security
    The Cisco Meraki MX68 is designed with advanced security features including Intrusion Detection System (IDS), Intrusion Prevention System (IPS), and firewall protection, ensuring your network remains secure against threats.
  • High connectivity
    With dual RJ-45 connectors for 1000Base-T and support for both wired and wireless connectivity, this security appliance ensures high-speed access for up to 50 users, making it ideal for small to medium-sized businesses.
  • Efficient performance
    Achieve optimal network performance with features like Quality of Service (QoS), load balancing, and traffic shaping. The MX68 supports a firewall throughput of 450 Mbps, VPN throughput of 200 Mbps, and advanced security throughput of 300 Mbps.
  • Versatile networking
    This device supports a wide range of networking protocols including Ethernet, Fast Ethernet, and Gigabit Ethernet, alongside DHCP, IPSec, and PPPoE, catering to diverse business needs.
  • Power over Ethernet
    Equipped with PoE+ support, the MX68 simplifies the deployment of network devices such as IP cameras and VoIP phones by transmitting power and data through a single cable.
Cisco Meraki MX68 - security appliance
Security appliance
Desktop
Ports Qty
10
Performance
Firewall throughput: 450 Mbps , VPN throughput: 200 Mbps , Advanced security throughput: 300 Mbps
Maximum number of users: 50
Power Over Ethernet (PoE) Supported
PoE+
28.4 cm x 14.8 cm x 2.7 cm
1.12 kg
Security appliance
28.4 cm
14.8 cm
2.7 cm
1.12 kg
Desktop
Ports Qty
10
Wired, wireless
Network / Transport Protocol
IPSec, DHCP, L2TP, PPPoE
Routing Protocol
Static IP routing, MPLS
Performance
3G/4G USB Dongle Support, NAT support, firewall protection, VLAN support, wall mountable, firmware upgradable, Link Aggregation, DMZ support, DHCP support, VPN client, content filtering, Intrusion Prevention System (IPS), Intrusion Detection System (IDS), IP Security (IPSec) support, IPSec Virtual Private Network (VPN), layer 7 switching, Quality of Service (QoS), load balancing, MPLS VPN, static routing, traffic shaping, 802.1x authentication
2 x 1000Base-T - RJ-45 (WAN) , 8 x 1000Base-T - RJ-45 , 2 x 1000Base-T (PoE+) - RJ-45 , 1 x USB 2.0 - Type A
PoE+
External power adapter
Installed Qty
1
Max Supported Qty
1
Power Provided
100 Watt
Limited warranty - advance hardware replacement - lifetime - response time: next day
5 - 95% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Brand: Meraki
