Meraki MX67W Router/Security Appliance with 802.11ac
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVPG
Quicklinx: DV6PWS00 Mfr#: MX67W-HW
  • IEEE 802.11n
£437.92 ex VAT
£525.50 inc VAT
Lockdown your network with the Cisco Meraki MX67W cloud-managed security & SD-WAN appliance that has 802.11ac Wave 2 Wi-Fi. Ideal for small retail branches or clinics, this device can routinely support up to 50 users and has a stateful firewall throughput of up to 450 Mbps. It allows a maximum of 50 simultaneous VPN sessions for absolutely secure data transfer and includes five Gigabit Ethernet interfaces so that you can connect a variety of devices to it.
Since the MX is 100% cloud managed, installation and remote management is simple. The MX has a comprehensive suite of security and network services including threat management and SD-WAN capabilities, eliminating the need for multiple appliances. Your business can use a central location to set up its retail outlets or clinics without having to travel. Template-based multi-network management allows you to quickly set up profiles and settings across thousands of devices to ensure it scales easily. Monitoring and reporting systems ensure you get email alerts that inform you of utilization metrics, and comprehensive changelogs make tracing modifications very quick.
Quickly secure your network with the intelligent WAN that includes policy-based routing and dynamic VPN path selection, and it has a variety of application-layer protocols and systems that ensure only authorized visitors get in. Threat management solutions include content filtering, intrusion prevention using a PCI-compliant IPS sensor, identity-based policies, and Advanced Malware Protection from Cisco for maximum protection. An enhanced CPU and plenty of memory ensure this Cisco Meraki cloud-managed security & SD-WAN appliance can process all the information flowing through it rapidly.
  • Enhanced connectivity
    With dual-band Wi-Fi 5 and support for 802.11a/b/g/n/ac wireless protocols, the Cisco Meraki MX67W ensures reliable and fast connectivity across both 2.4 GHz and 5 GHz bands. This versatility allows for optimal performance in a variety of network environments, accommodating a wide range of devices.
  • Robust security features
    The MX67W is equipped with comprehensive security features including firewall protection, intrusion detection and prevention systems (IDS/IPS), and security throughput of up to 300 Mbps. These features work together to safeguard your network from external threats and ensure secure data transmission.
  • High-performance networking
    Offering a firewall throughput of 450 Mbps and VPN throughput of 200 Mbps, the MX67W is designed to handle the demands of small to medium-sized businesses. Its capacity to support up to 50 users makes it an ideal solution for offices requiring high-speed, secure Internet access.
  • Versatile management options
    This security appliance supports features like DHCP support, NAT support, and Quality of Service (QoS), providing flexible and efficient network management. Its ability to support 3G/4G USB Dongle adds an extra layer of connectivity, ensuring continuous network access.
  • Easy installation and maintenance
    With its desktop form factor and external power adapter, the Cisco Meraki MX67W is easy to install and maintain. Firmware upgrades and traffic shaping capabilities further enhance its performance and reliability, making it a user-friendly solution for any business environment.
Cisco Meraki MX67W - security appliance - Wi-Fi 5
Security appliance
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Performance
Firewall throughput: 450 Mbps , VPN throughput: 200 Mbps , Advanced security throughput: 300 Mbps
Maximum number of users: 50
Mounting kit
23.9 cm x 16.4 cm x 2.7 cm
830 g
Security appliance
23.9 cm
16.4 cm
2.7 cm
830 g
Desktop
Wireless, wired
Data Transfer Rate
1.3 Gbps
Network / Transport Protocol
IPSec, DHCP
Routing Protocol
Static IP routing, MPLS
Frequency Band
2.4 GHz, 5 GHz
Performance
Firewall protection, DHCP support, NAT support, load balancing, layer 7 switching, VLAN support, traffic shaping, content filtering, Intrusion Detection System (IDS), Intrusion Prevention System (IPS), firmware upgradable, wall mountable, IPSec Virtual Private Network (VPN), Quality of Service (QoS), MPLS VPN, 3G/4G USB Dongle Support, static routing, 802.1x authentication, Link Aggregation, VPN client, IP Security (IPSec) support, DMZ support
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac Wave 2
Aerial
Antenna
External
Antenna Qty
2
4 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 1 x USB 2.0 - Type A
Mounting kit
2 x network cable
External power adapter
Installed Qty
1
Max Supported Qty
1
Power Provided
18 Watt
Limited warranty - advance hardware replacement - lifetime - response time: next day
45 °C
5 - 95% (non-condensing)
Brand: Meraki
