Meraki MX67 Router/Security Appliance
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVPF
Quicklinx: DV6NWS00 Mfr#: MX67-HW
£294.21 ex VAT
£353.05 inc VAT
Lockdown your network with the Cisco Meraki MX67 cloud-managed security & SD-WAN appliance. Ideal for small retail branches or clinics, this device can routinely support up to 50 users and has a stateful firewall throughput of up to 450 Mbps. It allows a maximum of 50 simultaneous VPN sessions for absolutely secure data transfer and includes five Gigabit Ethernet interfaces so that you can connect a variety of devices to it.
Since the MX is 100% cloud managed, installation and remote management is simple. The MX has a comprehensive suite of security and network services including threat management and SD-WAN capabilities, eliminating the need for multiple appliances. Your business can use a central location to set up its retail outlets or clinics without having to travel. Template-based multi-network management allows you to quickly set up profiles and settings across thousands of devices to ensure it scales easily. Monitoring and reporting systems ensure you get email alerts that inform you of utilization metrics, and comprehensive changelogs make tracing modifications very quick.
Quickly secure your network with the intelligent WAN that includes policy-based routing and dynamic VPN path selection, and it has a variety of application-layer protocols and systems that ensure only authorized visitors get in. Threat management solutions include content filtering, intrusion prevention using a PCI-compliant IPS sensor, identity-based policies, and Advanced Malware Protection from Cisco for maximum protection. An enhanced CPU and plenty of memory ensure this Cisco Meraki cloud-managed security & SD-WAN appliance can process all the information flowing through it rapidly.
  • Enhanced security
    The Cisco Meraki MX67 is equipped with robust security features including firewall protection, Intrusion Detection System (IDS), and Intrusion Prevention System (IPS), ensuring your network remains secure against threats.
  • Comprehensive connectivity
    Offering both wired and wireless connectivity options, along with support for Ethernet, Fast Ethernet, and Gigabit Ethernet, this security appliance ensures versatile and high-speed access for up to 50 users.
  • Efficient performance
    With a firewall throughput of 450 Mbps, VPN throughput of 200 Mbps, and advanced security throughput of 300 Mbps, the MX67 delivers reliable performance for your secure network needs.
  • Cloud-managed convenience
    Cloud-managed architecture allows for easy deployment and management, providing a streamlined experience for network administrators.
  • Flexible mobile solutions
    Support for 3G/4G USB Dongle and LTE cellular protocol offers flexible mobile broadband options, enhancing connectivity for remote users or sites.
Cisco Meraki MX67 - security appliance - cloud-managed
Security appliance
Desktop
Performance
Firewall throughput: 450 Mbps , VPN throughput: 200 Mbps , Advanced security throughput: 300 Mbps
Maximum number of users: 50
Mobile Communication Protocol
LTE
Mounting kit
23.9 cm x 13 cm x 2.7 cm
700 g
Security appliance
Built-in Devices
Modem
23.9 cm
13 cm
2.7 cm
700 g
Desktop
Wireless, wired
Network / Transport Protocol
DHCP
Routing Protocol
Static IP routing
Cloud-Managed
Performance
Firewall protection, DHCP support, NAT support, VLAN support, content filtering, Intrusion Detection System (IDS), Intrusion Prevention System (IPS), firmware upgradable, wall mountable, IPSec Virtual Private Network (VPN), anti-malware protection, 3G/4G USB Dongle Support, Link Aggregation, VPN client, IP Security (IPSec) support, DMZ support
Communications
LTE
Expansion Slots
1 SIM card
4 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 1 x USB 2.0 - Type A , 1 x modem
Mounting kit
2 x network cable
External power adapter
Installed Qty
1
Max Supported Qty
1
Power Provided
18 Watt
Limited warranty - advance hardware replacement - lifetime - response time: next day
45 °C
5 - 95% (non-condensing)
Brand: Meraki
