Meraki MX450 Router/Security Appliance
CALL FOR DETAILS ON LICENCING
Quicklinx: DV6TWS00 Mfr#: MX450-HW
£16,138.13 ex VAT
£19,365.75 inc VAT
The Meraki MX450 is a cloud-managed network security appliance designed for large brand and campus networks. It is able to provide high-bandwidth, secure, and easy to manage connectivity. Packed with layer 7 application firewalling and performance features like traffic shaping, VPN, SD-WAN capabilities, IPS and advanced malware protection, the MX450 is ideal for reducing overall IT cost while enhancing network reliability. With two 10G SFP+ dedicated uplink ports, and a variety of 1G and 10G LAN ports, MX450 is an ideal UTM solution for large branches, offices and campus environments.
  • Feature-rich unified threat management capabilities
    Flow-based protection engine. Identity-based security policies and application management.
  • Intelligent site-to-site VPN
    Automatic VPN route generation using IKE/IPsec setup. VPN path selection and support for application-layer performance profiles to ensure prioritization of the applications types that matter.
Cisco Meraki MX450 Cloud Managed - security appliance
Security appliance
Rack-mountable
Gigabit Ethernet
Performance
Firewall throughput: 6 Gbps , VPN throughput: 2 Gbps
VPN tunnels (site-to-site): 5000
Power Redundancy
Security appliance
Rack-mountable
Wired
Gigabit Ethernet
Network / Transport Protocol
TCP/IP, DHCP, IPSec
Remote Management Protocol
HTTP
Performance
Network monitoring, DMZ port, DHCP support, NAT support, VPN support, VLAN support, manageable, application level inspection, Link Aggregation, traffic shaping, Web Filtering, WAN failover, 3G/4G USB Dongle Support, firmware upgradable, Intrusion Prevention System (IPS), Intrusion Detection System (IDS)
Authentication Method
Active Directory
2 x 10Gb Ethernet - SFP+ (WAN) , 8 x 1000Base-T - RJ-45 , 8 x - SFP (mini-GBIC) , 8 x 10Gb Ethernet - SFP+ , 1 x USB - Type A
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Provided
250 watt
Limited warranty - lifetime - response time: next day
5 - 95% (non-condensing)
Brand: Meraki
Price Range Ex VAT: £1500+
