The MV family brings Meraki magic to the video security world. Impossibly simple to deploy, configure, and manage, both the MV21 and MV71 provide reliable security at any scale. MV21 features a simplified industrial design, cutting back even more on installation time and streamlining deployments.
By utilizing industrial grade, high write endurance solid state storage on each camera, the MV family has removed the NVR from the equation. Video records to the camera itself rather than relying on an external recording solution. The Meraki dashboard will automatically detect whether the viewing computer is in the local network or somewhere remote. Local streaming video never goes to the cloud, saving WAN bandwidth, while remote streaming video is proxied through the cloud, allowing it to be viewed from anywhere.
Laptop gone missing? Retroactively select the desk or conference table where it was last seen and the dashboard returns a list of motion events that can help lead to its recovery. Select important video segments and export from the dashboard to a shareable and downloadable link. With granular access controls, decide who has access to historical footage and exporting privileges. Easily search historical footage using natural language processing and go from identifying an event to sharing it in just a couple of clicks.
MV cameras come with everything needed for a successful deployment in the box. Add cameras to a network before they even arrive, and adjust focus, aperture, and zoom settings remotely. The Meraki dashboard's elegant interface allows for remote management, the way it should be.
Wide coverage
With an angular field of view ranging from 28° to 82° horizontally and 21° to 61° vertically, the Cisco Meraki MV21 offers comprehensive coverage, ensuring no corner is left unmonitored. -
Exceptional clarity
The MV21's lens aperture of f/1.3-2.5, combined with a vari-focal lens, allows for clear images under various lighting conditions, from 0.27 lux in color mode to as low as 0.001 lux in black and white. -
Reliable connectivity
Featuring Ethernet 10Base-T/100Base-TX interface with RJ-45 connector for LAN/power, this network surveillance camera ensures a stable and secure connection. -
Enhanced night vision
Equipped with infrared LEDs and capable of illuminating up to 30 m, the MV21 provides clear, detailed images even in complete darkness. -
Energy efficient
Operating on low voltage Power over Ethernet (PoE) and with a power consumption of just 10.94 watts, the MV21 is designed for energy efficiency.
- Cisco Meraki MV21 - network surveillance camera - dome
- Network surveillance camera - fixed - dome
- 16.6 cm x 16.6 cm x 11.6 cm
- 1.028 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 3.3 x
- Max Resolution
- 1280 x 720
- Video Modes
- 720p
- Optical Sensor Type
- CMOS - 1/3.2"
- Minimum Illumination
- 0.27 lux - colour - F1.3 , 0.001 lux - B&W - F1.3
- Focal Length Control
- Vari-focal
- Focal Length
- 3 mm - 10 mm
- Lens Iris
- F/1.3-2.5
- Panning Range (degree)
- 350
- Tilting Range (degree)
- 65
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- LED indicator, reset button
- 3-year warranty
- Environmental Parameters (operating)
- -20 °C - 50 °C
- Form Factor
- Dome
- Wired
- 16.6 cm
- 16.6 cm
- 11.6 cm
- 1.028 kg
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1280 x 720
- Video Modes
- 720p
- Exposure Range
- 1/5 sec - 1/32000 sec
- Infrared LEDs
- Infrared Distance
- 30 m
- Digital Video Capture Resolution
- 1280 x 720
- Flash Memory
- 128 GB
Image Sensor
- CMOS 1/3.2"
Lens Construction
- Vari-focal
- Optical Zoom
- 3.3 x
- Focal Length
- 3 mm - 10 mm
- Lens Iris
- F/1.3-2.5
- Horizontal Field of View (degree)
- 28 - 82
- Vertical Field of View (degree)
- 21 - 61
Panning
- Range (degree)
- 350
Tilting
- Range (degree)
- 65
- Network Interface
- Network Protocols
- DSCP
- Ports
- LAN/power - RJ-45
- Included Accessories
- Wall mount kit, ceiling T-rail mounting hardware
- Plug and Play, AES-256, IEEE 802.3af
- Power Requirements
- PoE
- Power Device
- 10.94 Watt
- Limited warranty - advance parts replacement - 3 years
- -20 °C
- 50 °C
