The Cisco Meraki MS425-32 is a 32-port 10GbE cloud-managed stackable L3 enterprise-class aggregation switch with two QSFP+ 40G uplinks and support for redundant power supplies for mission critical environments. The MS425 family includes integrated client and layer 7 application visibility, remote troubleshooting tools like live packet capture and cable test. The MS425 family is 100% cloud-managed via the intuitive, browser-based Meraki dashboard, and includes a rich, out-of-the-box feature set without additional cost and complexity.
Robust security
Equipped with RADIUS authentication and compliance with multiple standards including C-Tick, CSA, IC, and RoHS, this switch ensures a secure networking environment, safeguarding your data and communications. -
High performance
With a switching capacity of 800 Gbps and support for up to 4095 tagged VLANs, this switch delivers exceptional performance for high-demand network environments. -
Advanced connectivity
Featuring 24 10 Gigabit SFP+ ports and 2 40 Gigabit QSFP+ uplink ports, this switch offers ample bandwidth and high-speed connectivity options for linking with other network switches or devices. -
Efficient management
Cloud managed with Zero Touch Auto Provisioning and a comprehensive suite of features including layer 3 switching, port mirroring, and Quality of Service (QoS), this switch simplifies network setup and management. -
Reliable operation
Designed for durability and long-term reliability, it operates efficiently between 0°C and 40°C with front to back airflow, and boasts an impressive MTBF of 431,380 hours.
 - Cisco Meraki Cloud Managed Ethernet Aggregation Switch MS425-32 - switch - 32 ports - Managed - rack-mountable
 - Switch - 32 ports - Managed - stackable
- Enclosure Type
 - Front to back airflow rack-mountable 1U
- Subtype
 - 10 Gigabit Ethernet
- Ports
 - 24 x 10 Gigabit SFP+ + 2 x 40 Gigabit QSFP+ (uplink)
- Performance
 - Switching capacity: 800 Gbps
- Capacity
 - Tagged VLANs: 4095
- Routing Protocol
 - OSPFv2, static IP routing
 - Layer 3 switching, DHCP support, VLAN support, IGMP snooping, port mirroring, E-mail alert, Broadcast Storm Control, firmware upgradable, STP support, RSTP support, QoS, SMS alert, LLDP support, LACP, Zero Touch Auto Provisioning, tagged VLAN, cloud managed
 - IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ad, IEEE 802.1ab (LLDP)
- Power
 - AC 120/230 V (47 - 63 Hz)
 - 48.5 cm x 48.7 cm x 4.5 cm
 - 6.35 kg
 - Limited lifetime warranty
- Enclosure Type
- Subtype
- Ports
- Performance
- Capacity
- Routing Protocol
- Authentication Method
 - RADIUS
 - 24 x 1000Base-X SFP+ , 2 x 40Gbit LAN QSFP+ uplink/stacking , 1 x management (Gigabit LAN) RJ-45
- Power Device
 - Internal power supply
- Voltage Required
- MTBF
 - 431,380 hours
 - CSA, C-Tick, IC, RoHS
 - 48.5 cm
 - 48.7 cm
 - 4.5 cm
 - 6.35 kg
 - Limited warranty - advance hardware replacement - lifetime - response time: next day
 - 0 °C
 - 40 °C
