Meraki MS410-32-port Cloud Managed GigE SFP Switch
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVQN
Quicklinx: DV8HWS00 Mfr#: MS410-32-HW
Type: Gigabit Ethernet
Ports: 32
Managed: Yes
£11,293.66 ex VAT
£13,552.39 inc VAT
The Cisco Meraki MS410-32 is a 32-port 1GbE cloud-managed stackable L3 enterprise-class distribution switch with four SFP+ uplinks and support for redundant power supplies for mission critical environments. The MS410 family includes integrated client and layer 7 application visibility, remote troubleshooting tools like live packet capture and cable test. The MS410 family is 100% cloud-managed via the intuitive, browser-based Meraki dashboard, and includes a rich, out-of-the-box feature set without additional cost and complexity.
  • Robust performance
    With a switching capacity of 72 Gbps, the Cisco Meraki Cloud Managed Ethernet Aggregation Switch MS410-32 ensures high-speed data transmission and efficient handling of network traffic, making it ideal for growing businesses.
  • Comprehensive connectivity
    Equipped with 32 Gigabit SFP ports and 4 additional 10 Gigabit SFP+ uplink ports, this switch offers ample connectivity options for a variety of devices and network layouts, supporting both current and future network infrastructure needs.
  • Enhanced network security
    Features such as 802.1x authentication, DHCP snooping, and RADIUS support provide a secure network environment by protecting against unauthorized access and network threats.
  • Efficient network management
    Manageable via HTTP and SNMP, the switch allows for easy setup and management, while features like SMS and e-mail alerts keep administrators informed of network status in real time.
  • Reliable operation
    Designed for durability and long-term reliability, it boasts an MTBF of 437,593 hours and operates effectively in temperatures ranging from 0°C to 40°C, ensuring consistent performance under various environmental conditions.
Cisco Meraki Cloud Managed Ethernet Aggregation Switch MS410-32 - switch - 32 ports - Managed - rack-mountable
Switch - 32 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
32 x Gigabit SFP + 4 x 10 Gigabit SFP+ (uplink)
Performance
Switching capacity: 72 Gbps
Tagged VLANs: 4095
MAC Address Table Size
96K entries
Routing Protocol
VRRP, OSPFv2, static IP routing
Remote Management Protocol
SNMP, HTTP
VLAN support, IGMP snooping, port mirroring, E-mail alert, Broadcast Storm Control, firmware upgradable, STP support, RSTP support, DHCP snooping, QoS, DHCP server, SMS alert, LACP support, DHCP relay, tagged VLAN, 802.1x authentication, BPDU
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ab (LLDP)
48.5 cm x 51.6 cm x 4.5 cm
5.7 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Tagged VLANs: 4095
96K entries
Max Units In A Stack
8
Routing Protocol
SNMP, HTTP
Authentication Method
RADIUS
32 x 1000Base-X SFP , 4 x 10GBase-X SFP+ uplink , 1 x management (Gigabit LAN) RJ-45
Internal power supply
85 Watt
Front-to-rear airflow
MTBF
437,593 hours
CSA, C-Tick, IC, RoHS
48.5 cm
51.6 cm
4.5 cm
5.7 kg
Limited warranty - advance hardware replacement - lifetime - response time: next day
Ports: 32
Managed: Yes
Brand: Meraki
Price Range Ex VAT: £1500+
