Meraki MS410-16-port Cloud Managed GigE SFP Switch
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVQM
Quicklinx: DV8GWS00 Mfr#: MS410-16-HW
Type: Gigabit Ethernet
Ports: 16
Managed: Yes
£6,124.88 ex VAT
£7,349.85 inc VAT
The Cisco Meraki MS410-16 is a 16-port 1GbE cloud-managed stackable L3 enterprise-class distribution switch with two SFP+ uplinks and support for redundant power supplies for mission critical environments. The MS410 family includes integrated client and layer 7 application visibility, remote troubleshooting tools like live packet capture and cable test. The MS410 family is 100% cloud-managed via the intuitive, browser-based Meraki dashboard, and includes a rich, out-of-the-box feature set without additional cost and complexity.
  • Robust performance
    With a switching capacity of 72 Gbps, the Cisco Meraki Cloud Managed Ethernet Aggregation Switch MS410-16 ensures high-speed data transmission and efficient network traffic management, making it ideal for growing businesses.
  • Comprehensive connectivity
    Equipped with 16 Gigabit SFP ports and 2 additional 10 Gigabit SFP+ uplink ports, this switch offers ample connectivity options for a variety of devices and network layouts, supporting both current and future network infrastructure needs.
  • Enhanced reliability
    Featuring a mean time between failures (MTBF) of 875,186 hours, the MS410-16 is designed for long-term reliability and minimal downtime, ensuring your network remains operational when you need it most.
  • Advanced network features
    From Quality of Service (QoS) to support for VLANs and port mirroring, the MS410-16 comes loaded with features that enhance network efficiency, security, and manageability.
  • Efficient management and operation
    This switch supports remote management protocols such as HTTP and SNMP, allowing for easy configuration and monitoring. Its internal power supply with front-to-rear airflow design ensures efficient operation and cooling.
Cisco Meraki Cloud Managed Ethernet Aggregation Switch MS410-16 - switch - 16 ports - Managed - rack-mountable
Switch - 16 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16 x Gigabit SFP + 2 x 10 Gigabit SFP+ (uplink)
Performance
Switching capacity: 72 Gbps
Tagged VLANs: 4095
MAC Address Table Size
96K entries
Routing Protocol
VRRP, OSPFv2, static IP routing
Remote Management Protocol
SNMP, HTTP
VLAN support, IGMP snooping, port mirroring, E-mail alert, Broadcast Storm Control, firmware upgradable, STP support, RSTP support, DHCP snooping, QoS, DHCP server, SMS alert, LACP support, DHCP relay, tagged VLAN, 802.1x authentication, BPDU
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ab (LLDP)
48.5 cm x 51.6 cm x 4.5 cm
5.7 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Tagged VLANs: 4095
96K entries
Max Units In A Stack
8
Routing Protocol
SNMP, HTTP
Authentication Method
RADIUS
16 x 1000Base-X SFP , 2 x 10GBase-X SFP+ uplink , 1 x management (Gigabit LAN) RJ-45
Internal power supply
85 watt
Front-to-rear airflow
MTBF
875,186 hours
CSA, C-Tick, IC, RoHS
48.5 cm
51.6 cm
4.5 cm
5.7 kg
Limited warranty - advance hardware replacement - lifetime - response time: next day
Ports: 16
Managed: Yes
Brand: Meraki
Price Range Ex VAT: £1500+
