Meraki MS350-48FP L3 Stck 48-port Cloud Managed GigE 740W PoE+ Switch
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVQK
Quicklinx: DV8FWS00 Mfr#: MS350-48FP-HW
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
POE: PoE+
£5,045.19 ex VAT
£6,054.22 inc VAT
The Cisco Meraki MS350-48FP is a 48-port GbE 740W PoE/PoE+ cloud-managed stackable L3 enterprise-class access switch with four SFP+ uplinks and support for redundant power supplies for mission critical environments. The MS350 family includes integrated client and layer 7 application visibility, remote troubleshooting tools like live packet capture and cable test. The MS350 family is 100% cloud-managed via the intuitive, browser-based Meraki dashboard, and includes a rich, out-of-the-box feature set without additional cost and complexity.
  • Centrally managed from the cloud
    The Cisco Meraki Cloud Networking architecture enables Plug and Play branch deployments and provides centralized visibility and control across any number of distributed locations. The Cisco Meraki MS is the industry's cloud managed switch, combining the benefits of cloud-based centralized management with a powerful, reliable access platform. With cloud management, thousands of switch ports can be configured and monitored instantly, over the web. Provision remote sites without on-site IT, deploy network-wide configuration changes, and easily manage campus and distributed networks without training or dedicated staff.
  • Layer 7 application and client visibility
    Cisco Meraki MS Switches are the industry's only switches featuring integrated Layer 7 application and client fingerprinting and analysis. Hundreds of applications are automatically identified and reported, from business apps to BitTorrent and YouTube, so administrators can see where resources are spent.
  • QoS for voice and video
    Deploy latency-sensitive applications such as voice and video by guaranteeing network performance. Voice and QoS features such as per-VLAN and protocol-based prioritization, as well as flexible QoS assignments, give intuitive, granular control.
  • Enterprise security
    Extending security down to the port level has never been easier. MS Switches integrate seamlessly with enterprise-grade security systems using 802.1x. Define access policies, segregate guest devices, and quarantine entire environments right from the dashboard.
Cisco Meraki Cloud Managed MS350-48FP - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 4 x 10 Gigabit SFP+ (uplink)
Power Over Ethernet (PoE)
PoE+
PoE Budget
740 W
Performance
Non-blocking switching capacity: 176 Gbps
Forwarding table entries: 96000 , Tagged VLANs: 4096
Jumbo Frame Support
9600 bytes
Routing Protocol
OSPFv2, static IP routing
Remote Management Protocol
SNMP 2c
Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, E-mail alert, Broadcast Storm Control, firmware upgradable, STP support, RSTP support, ACL support, QoS, SMS alert, LLDP support, DHCP client, tagged VLAN, crossover detection
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.1ab (LLDP), IEEE 802.3at
Power Redundancy
Optional
48.5 cm x 55.4 cm x 4.4 cm
6.8 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
740 W
Performance
Jumbo Frame Support
9600 bytes
Routing Protocol
SNMP 2c
Authentication Method
RADIUS
48 x 1000Base-T RJ-45 PoE+ - 25.5 W , 4 x 10Gbit LAN SFP+ uplink
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Power Provided
1025 Watt
885 Watt
Rack Mounting Kit
Included
MTBF
516,000 hours
CSA, C-Tick, IC, RoHS
48.5 cm
55.4 cm
4.4 cm
6.8 kg
Limited warranty - replacement - lifetime - response time: next day
45 °C
5 - 95% (non-condensing)
Ports: 48
Managed: Yes
POE: PoE+
Brand: Meraki
Price Range Ex VAT: £1500+
