Meraki MS250-48FP L3 Stck 48-port Cloud Managed GigE 740W PoE+ Switch
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVQC
Quicklinx: DV7TWS00 Mfr#: MS250-48FP-HW
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
POE: PoE+
£4,203.05 ex VAT
£5,043.66 inc VAT
The Cisco Meraki MS250-24 is a 24-port cloud-managed stackable enterprise-class access switch with four SFP+ uplinks, support for redundant power supplies for mission critical environments, and IP routing. The MS250 family includes integrated client and layer 7 application visibility, remote troubleshooting tools like live packet capture and cable test. The MS250 family is 100% cloud-managed via the intuitive, browser-based Meraki dashboard, and includes a rich, out-of-the-box feature set without additional cost and complexity.
  • Centrally managed from the cloud
    The Cisco Meraki Cloud Networking architecture enables Plug and Play branch deployments and provides centralized visibility and control across any number of distributed locations. The Cisco Meraki MS is the industry's cloud managed switch, combining the benefits of cloud-based centralized management with a powerful, reliable access platform. With cloud management, thousands of switch ports can be configured and monitored instantly, over the web. Provision remote sites without on-site IT, deploy network-wide configuration changes, and easily manage campus and distributed networks without training or dedicated staff.
  • Layer 7 application and client visibility
    Cisco Meraki MS Switches are the industry's only switches featuring integrated Layer 7 application and client fingerprinting and analysis. Hundreds of applications are automatically identified and reported, from business apps to BitTorrent and YouTube, so administrators can see where resources are spent.
  • QoS for voice and video
    Deploy latency-sensitive applications such as voice and video by guaranteeing network performance. Voice and QoS features such as per-VLAN and protocol-based prioritization, as well as flexible QoS assignments, give intuitive, granular control.
  • Enterprise security
    Extending security down to the port level has never been easier. MS Switches integrate seamlessly with enterprise-grade security systems using 802.1x. Define access policies, segregate guest devices, and quarantine entire environments right from the dashboard.
Cisco Meraki Cloud Managed MS250-48FP - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 4 x SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
740 W
Performance
Stacking bandwidth: 80 Gbps , Switching capacity: 176 Gbps
MAC Address Table Size
32K entries
Jumbo Frame Support
9600 bytes
Routing Protocol
IGMP, VRRP, OSPFv2
Remote Management Protocol
SNMP, HTTP
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, E-mail alert, Broadcast Storm Control, STP support, RSTP support, VRRP support, DHCP snooping, ACL support, QoS, DHCP server, LLDP support, DHCP relay, Port Security, DHCP client, e-mail notification, Zero Touch Auto Provisioning, static routing, Multicast filtering function, 802.1x authentication, cable test, BPDU, Link Aggregation, RBAC, push notification, Root Guard
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ab (LLDP), IEEE 802.3at
AC 120/230 V (40 - 60 Hz)
Power Redundancy
48.46 cm x 51.6 cm x 4.38 cm
5.82 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
740 W
Performance
32K entries
Jumbo Frame Support
9600 bytes
Max Units In A Stack
8
Routing Protocol
IGMP, VRRP, OSPFv2
SNMP, HTTP
Authentication Method
RADIUS
Status Indicators
Status
48 x 1000Base-T RJ-45 PoE+ - 25.5 W , 4 x 10GBase-X SFP+ uplink , 2 x network stack device
Internal power supply
Power Redundancy
Rack Mounting Kit
Included
CSA, IC, FCC, RoHS, RCM
48.46 cm
51.6 cm
4.38 cm
5.82 kg
Limited warranty - lifetime
5 - 90% (non-condensing)
Ports: 48
Managed: Yes
POE: PoE+
Brand: Meraki
Price Range Ex VAT: £1500+
