The Cisco Meraki MS250-24 is a 24-port cloud-managed stackable enterprise-class access switch with four SFP+ uplinks, support for redundant power supplies for mission critical environments, and IP routing. The MS250 family includes integrated client and layer 7 application visibility, remote troubleshooting tools like live packet capture and cable test. The MS250 family is 100% cloud-managed via the intuitive, browser-based Meraki dashboard, and includes a rich, out-of-the-box feature set without additional cost and complexity.
                Centrally managed from the cloudThe Cisco Meraki Cloud Networking architecture enables Plug and Play branch deployments and provides centralized visibility and control across any number of distributed locations. The Cisco Meraki MS is the industry's cloud managed switch, combining the benefits of cloud-based centralized management with a powerful, reliable access platform. With cloud management, thousands of switch ports can be configured and monitored instantly, over the web. Provision remote sites without on-site IT, deploy network-wide configuration changes, and easily manage campus and distributed networks without training or dedicated staff.
                Layer 7 application and client visibilityCisco Meraki MS Switches are the industry's only switches featuring integrated Layer 7 application and client fingerprinting and analysis. Hundreds of applications are automatically identified and reported, from business apps to BitTorrent and YouTube, so administrators can see where resources are spent.
                QoS for voice and videoDeploy latency-sensitive applications such as voice and video by guaranteeing network performance. Voice and QoS features such as per-VLAN and protocol-based prioritization, as well as flexible QoS assignments, give intuitive, granular control.
                Enterprise securityExtending security down to the port level has never been easier. MS Switches integrate seamlessly with enterprise-grade security systems using 802.1x. Define access policies, segregate guest devices, and quarantine entire environments right from the dashboard.
- Cisco Meraki Cloud Managed MS250-24P - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE+) + 4 x 10 Gigabit SFP+ (uplink)
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 370 W
- Performance
- Switching capacity: 128 Gbps
- Capacity
- Forwarding table entries: 16000 , Tagged VLANs: 4095
- Jumbo Frame Support
- 9600 bytes
- Routing Protocol
- VRRP, OSPFv2, static IP routing
- Remote Management Protocol
- SNMP
- Flow control, DHCP support, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, E-mail alert, Broadcast Storm Control, firmware upgradable, STP support, RSTP support, ACL support, QoS, Jumbo Frames support, DHCP server, SMS alert, IPv4 support, LLDP support, DHCP relay, LACP, static routing, crossover detection, cloud managed, BPDU, RBAC, Cisco Discovery Protocol, Root Guard
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ab (LLDP), IEEE 802.3at
- Power
- AC 120/230 V (47 - 63 Hz)
- Power Redundancy
- Optional
- 48.46 cm x 41.6 cm x 4.38 cm
- 4.8 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 370 W
- Performance
- Capacity
- 9600 bytes
- Max Units In A Stack
- 8
- Routing Protocol
- SNMP
- Authentication Method
- RADIUS
- 24 x 1000Base-T RJ-45 PoE+ - 30 W , 4 x 10Gbit LAN SFP+ uplink
- Power Device
- Internal power supply
- Power Redundancy
- Optional
- Voltage Required
- MTBF
- 403,717 hours
- CSA, IC, FCC, RoHS, RCM
- 48.46 cm
- 41.6 cm
- 4.38 cm
- 4.8 kg
- Limited warranty - advance parts replacement - lifetime - response time: next day
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
