Meraki MS210-24 1G L2 24-ports Cloud Managed GigE Switch
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVPY
Quicklinx: DV74WS00 Mfr#: MS210-24-HW
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
POE: PoE
£1,251.56 ex VAT
£1,501.87 inc VAT
The Cisco Meraki Cloud Networking architecture enables Plug and Play branch deployments and provides centralized visibility and control across any number of distributed locations. The Cisco Meraki MS is the industry's cloud managed switch, combining the benefits of cloud-based centralized management with a powerful, reliable access platform. With cloud management, thousands of switch ports can be configured and monitored instantly, over the web. Provision remote sites without on-site IT, deploy network-wide configuration changes, and easily manage campus and distributed networks without training or dedicated staff.
Cisco Meraki MS Switches feature virtual stacking - an industry first - that allows management of thousands of switch ports as one, without requiring a physical connection between switches. Quickly find and configure switch ports across your entire network, even those in geographically-distributed locations. Easily configure ports for access devices, assign voice VLANs, control PoE, and more, with a few simple clicks and without complex CLI instructions.
  • Centrally managed from the cloud
  • Layer 7 application and client visibility
    Cisco Meraki MS Switches are the industry's only switches featuring integrated Layer 7 application and client fingerprinting and analysis. Hundreds of applications are automatically identified and reported, from business apps to BitTorrent and YouTube, so administrators can see where resources are spent.
  • QoS for voice and video
    Deploy latency-sensitive applications such as voice and video by guaranteeing network performance. Voice and QoS features such as per-VLAN and protocol-based prioritization, as well as flexible QoS assignments, give intuitive, granular control.
  • Enterprise security
    Extending security down to the port level has never been easier. MS Switches integrate seamlessly with enterprise-grade security systems using 802.1x. Define access policies, segregate guest devices, and quarantine entire environments right from the dashboard.
Cisco Meraki Cloud Managed MS210-24 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x Gigabit SFP (uplink)
Performance
Stacking bandwidth: 80 Gbps , Switching capacity: 128 Gbps , Forwarding rate: 41.67 Mpps
MAC Address Table Size
16K entries
Jumbo Frame Support
9578 bytes
Remote Management Protocol
SNMP
Flow control, auto-negotiation, ALERT notification, auto-uplink (auto MDI/MDI-X), Syslog support, Broadcast Storm Control, STP support, RSTP support, DHCP snooping, ACL support, fanless, LLDP support, DHCP relay, LACP, Port Security, DHCP client, static routing, 802.1x authentication, crossover detection, BPDU, RBAC, Root Guard
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ab (LLDP)
AC 120/230 V (50 - 60 Hz)
48.46 cm x 25 cm x 4.38 cm
2.73 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9578 bytes
SNMP
Authentication Method
RADIUS
24 x 1000Base-T RJ-45 , 4 x 1000Base-X SFP uplink , 2 x network stack device
Internal power supply
Feet set
Rack Mounting Kit
Included
MTBF
590,165 hours
CSA, IC, FCC, RoHS, RCM
48.46 cm
25 cm
4.38 cm
2.73 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
5 - 95% (non-condensing)
Ports: 24
Managed: Yes
POE: PoE
Brand: Meraki
Price Range Ex VAT: £1000 - £1500
