Meraki MS120-48FP 1G L2 Cld Managed 48x GigE 740W PoE Switch
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVPX
Quicklinx: DV73WS00 Mfr#: MS120-48FP-HW
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
POE: PoE
£2,996.66 ex VAT
£3,595.99 inc VAT
Meraki MS120 switches provide Layer 2 access switching ideal for branch and campus deployments. The MS120 series features a variety of power options designed to meet the diverse needs of large enterprise networks. Cisco Meraki switches are built from the ground up for cloud management without compromising any of the power and flexibility traditionally found in enterprise-class switches. All Cisco Meraki switches are managed through an elegant, intuitive cloud interface, rather than a cryptic command line. To bring up a Meraki switch, just plug it in; there’s no need for complicated configuration files or even direct physical access to the switch. Meraki’s centralized management gives administrators deep visibility into the network and how it’s used. See which switches are near capacity across hundreds of sites. Find all configuration changes made by a certain person with instant search.
  • Centrally managed from the cloud
    The Cisco Meraki Cloud Networking architecture enables Plug and Play branch deployments and provides centralized visibility and control across any number of distributed locations. The Cisco Meraki MS is the industry's cloud managed switch, combining the benefits of cloud-based centralized management with a powerful, reliable access platform. With cloud management, thousands of switch ports can be configured and monitored instantly, over the web. Provision remote sites without on-site IT, deploy network-wide configuration changes, and easily manage campus and distributed networks without training or dedicated staff.
  • Layer 7 application and client visibility
    Cisco Meraki MS Switches are the industry's only switches featuring integrated Layer 7 application and client fingerprinting and analysis. Hundreds of applications are automatically identified and reported, from business apps to BitTorrent and YouTube, so administrators can see where resources are spent.
  • QoS for voice and video
    Deploy latency-sensitive applications such as voice and video by guaranteeing network performance. Voice and QoS features such as per-VLAN and protocol-based prioritization, as well as flexible QoS assignments, give intuitive, granular control.
  • Enterprise security
    Extending security down to the port level has never been easier. MS Switches integrate seamlessly with enterprise-grade security systems using 802.1x. Define access policies, segregate guest devices, and quarantine entire environments right from the dashboard.
Cisco Meraki Cloud Managed MS120-48FP - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE) + 4 x Gigabit SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
740 W
Performance
Switching capacity: 104 Gbps , Forwarding rate: 77.38 Mpps
VLANs supported: 4094 , MAC forwarding entries: 32000
Jumbo Frame Support
9578 bytes
Remote Management Protocol
SNMP
Flow control, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, E-mail alert, Broadcast Storm Control, firmware upgradable, STP support, RSTP support, DHCP snooping, ACL support, QoS, SMS alert, STP Root Guard, DHCP client, crossover detection, SSO support, RBAC, Cisco Discovery Protocol, STP BPDU Guard, ZTP, DSCP to CoS Mutation
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ab (LLDP)
AC 120/230 V (47 - 63 Hz)
44 cm x 25 cm x 4.4 cm
4.37 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
740 W
Performance
Jumbo Frame Support
9578 bytes
SNMP
Authentication Method
RADIUS
48 x 1000Base-T RJ-45 PoE , 4 x 1000Base-T SFP
Internal power supply
Rack Mounting Kit
Included
MTBF
731,534 hours
CSA, IC, FCC, RoHS, RCM
44 cm
25 cm
4.4 cm
4.37 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
5 - 95% (non-condensing)
Ports: 48
Managed: Yes
POE: PoE
Brand: Meraki
Price Range Ex VAT: £1500+
