Meraki MS120-24 1G L2 24-ports Cloud Managed GigE Switch
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVPR
Quicklinx: DV6ZWS00 Mfr#: MS120-24-HW
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
£1,083.42 ex VAT
£1,300.10 inc VAT
Cisco Meraki MS120 switches provide Layer 2 access switching ideal for branch and campus deployments.
Cisco Meraki switches are managed through an elegant, intuitive cloud interface, rather than a cryptic command line. To bring up a Meraki switch, just plug it in; there's no need for complicated configuration files or even direct physical access to the switch.
Cloud management has a number of benefits that make it easier to build networks large and small: True zero-touch device provisioning; Virtual Stacking: manage up to thousands of ports from a single pane of glass; Application-layer visibility with automatic operating system, client, and hostname fingerprinting; Powerful live tools such as packet capture and cable test to isolate and troubleshoot network issues; Alerts to indicate power loss, downtime, excessive Layer 1 issues, and configurations changes; Role-based administration and automatic, scheduled firmware upgrades over the cloud; Regular feature updates and enhancements delivered on demand from the Meraki cloud.
  • Centrally managed from the cloud
    The Cisco Meraki Cloud Networking architecture enables Plug and Play branch deployments and provides centralized visibility and control across any number of distributed locations. The Cisco Meraki MS is the industry's cloud managed switch, combining the benefits of cloud-based centralized management with a powerful, reliable access platform. With cloud management, thousands of switch ports can be configured and monitored instantly, over the web. Provision remote sites without on-site IT, deploy network-wide configuration changes, and easily manage campus and distributed networks without training or dedicated staff.
  • Layer 7 application and client visibility
    Cisco Meraki MS Switches are the industry's only switches featuring integrated Layer 7 application and client fingerprinting and analysis. Hundreds of applications are automatically identified and reported, from business apps to BitTorrent and YouTube, so administrators can see where resources are spent.
  • QoS for voice and video
    Deploy latency-sensitive applications such as voice and video by guaranteeing network performance. Voice and QoS features such as per-VLAN and protocol-based prioritization, as well as flexible QoS assignments, give intuitive, granular control.
  • Enterprise security
    Extending security down to the port level has never been easier. MS Switches integrate seamlessly with enterprise-grade security systems using 802.1x. Define access policies, segregate guest devices, and quarantine entire environments right from the dashboard.
Cisco Meraki Cloud Managed MS120-24 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x Gigabit SFP
Performance
Switching capacity: 56 Gbps , Forwarding rate: 41.67 Mpps
VLANs supported: 4094 , MAC forwarding entries: 16000
Jumbo Frame Support
9578 bytes
Remote Management Protocol
SNMP
Flow control, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, E-mail alert, Broadcast Storm Control, firmware upgradable, STP support, RSTP support, DHCP snooping, ACL support, QoS, SMS alert, STP Root Guard, fanless, DHCP client, crossover detection, SSO support, RBAC, Cisco Discovery Protocol, STP BPDU Guard, ZTP, DSCP to CoS Mutation
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1ab (LLDP)
AC 120/230 V (47 - 63 Hz)
44 cm x 25 cm x 4.4 cm
2.73 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
Jumbo Frame Support
9578 bytes
SNMP
Authentication Method
RADIUS
24 x 1000Base-T RJ-45 , 4 x 1000Base-T SFP
Internal power supply
Rack Mounting Kit
Included
MTBF
1,179,789 hours
CSA, IC, FCC, RoHS, RCM
44 cm
25 cm
4.4 cm
2.73 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
5 - 95% (non-condensing)
Ports: 24
Managed: Yes
Brand: Meraki
Price Range Ex VAT: £1000 - £1500
