Meraki MR70 Cloud Managed Access Point
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVQR
Quicklinx: DV8XWS00 Mfr#: MR70-HW
  • IEEE 802.11n
£676.34 ex VAT
£811.60 inc VAT
The Cisco Meraki MR70 is a dual-radio, cloud-managed 2x2:2 802.11ac Wave 2 access point with MU-MIMO support. Designed for basic, best-effort deployments that require rapid installation, the MR70 provides enterprise-grade security and simple management in a ruggedized, IP67-rated form factor that sports integrated omnidirectional antennas.
The MR70 is ideal for municipal athletic fields, garages, public gardens, space constrained outdoor deployments, and even rapid response emergency kits designed to quickly deliver wireless in disaster-struck areas.
  • Robust security
    Equipped with advanced encryption algorithms including AES, WPA2-Enterprise, and WPA2-PSK, the Cisco Meraki MR70 ensures a secure wireless network environment, effectively protecting sensitive data from potential threats.
  • Exceptional connectivity
    Featuring 2T2R MIMO and MU-MIMO technology, the MR70 delivers high-speed data transfer rates up to 1.3 Gbps, ensuring seamless connectivity and enhanced user experience for high-bandwidth applications.
  • Comprehensive compliance
    The MR70 meets a wide range of compliance standards, including IP67 for environmental resilience and multiple IEEE standards, ensuring reliable performance in diverse operational conditions.
  • Versatile deployment
    With its wall-mountable form factor and support for PoE+, the MR70 offers flexible installation options and easy integration into various environments, making it an ideal solution for extending wireless coverage.
  • Intelligent management
    Cloud-managed with a full suite of features such as traffic shaping, firmware upgrades, and Wi-Fi Multimedia (WMM) support, the MR70 simplifies network administration and enhances operational efficiency.
Cisco Meraki MR70 - radio access point - Wi-Fi 5 - cloud-managed
Radio access point
Wall mountable
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Wall mounting kit
Power Over Ethernet (PoE) Supported
PoE
24.5 cm x 11.5 cm x 3 cm
450 g
1-year warranty
Radio access point
24.5 cm
11.5 cm
3 cm
450 g
Wall mountable
Wireless
Data Transfer Rate
1.3 Gbps
Network / Transport Protocol
IPSec
Cloud-Managed
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, Boot State, status
Hardware encryption, traffic shaping, firmware upgradable, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), PoE+, 2T2R MIMO technology, Maximum Ratio Combining (MRC), Wireless Intrusion Prevention System (WIPS), tagged VLAN, security lock slot (cable lock sold separately), DiffServ Code Point (DSCP) support, MU-MIMO technology, Bluetooth Low Energy Beaconing, Unscheduled Automatic Power Save Delivery (U-APSD), SU-MIMO technology
Encryption Algorithm
AES, TLS, TTLS, TKIP, WPA, WPA2-PSK, WPA2-Enterprise, WEP, EAP-SIM
Authentication Method
MS-CHAP v.2
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11r
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x 1000Base-T (PoE) - RJ-45
Wall mounting kit
ICES-003, EN55024, FCC Part 15 B, RSS-102, FCC Part 15 C, RoHS, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, FCC Part 15 E, IP67, EN 62311, EN 300 328, EN 50385, LP0002, RSS-247, EN 301 489-1-17, EN 62479, EN 301 893, CISPR 32, EN 55032, CAN/CSA-C22.2 No. 60950-1, EMI Class B, AS/NZS 2772
PoE
11 Watt
Limited warranty - advance parts replacement - 1 year
-20 °C
55 °C
Type: Radio access point
Connectivity: Wireless
Speed: 1.3Gbps
Protocol: IEEE 802.11ac Wave 2
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Brand: Meraki
Price Range Ex VAT: £500 - £750
