Meraki MR42 Cloud Managed Access Point
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVQR
Quicklinx: DV8RWS00 Mfr#: MR42-HW
Type: Radio access point
Connectivity: Wireless
Speed: 1.9Gbps
Protocol: IEEE 802.11a, IEEE 802.11n, IEEE 802.11ac Wave 2, IEEE 802.11b + 1 more
Compatibility: PC
  • IEEE 802.11n
£665.59 ex VAT
£798.70 inc VAT
The Cisco Meraki MR42 is a four radio, cloud-managed 3x3 MU-MIMO 802.11ac Wave 2 access point. Designed for high-performance, high-density next-generation deployments in offices, schools, hospitals, shops, and hotels, the MR42 offers performance, security, and simple management. The MR42 provides a maximum 1.9 Gbps aggregate dual-band frame rate with concurrent 802.11ac Wave 2 and 802.11n 3x3:3 MIMO radios. A dedicated third radio provides real-time WIDS/ WIPS with automated RF optimization. In addition, an integrated fourth radio delivers Bluetooth Low Energy (BLE) scanning and Beaconing functionality. The MR42 is 100% cloud-managed via the intuitive, browser-based Meraki Dashboard, and includes a rich, out-of-the-box feature set without additional cost or complexity.
  • Enhanced connectivity
    The MR42 Cloud Managed offers seamless integration with 1000Base-T (PoE+) connectivity, ensuring high-speed Internet access and efficient power management for businesses.
  • Robust security
    Equipped with multiple encryption algorithms including AES, WPA2-Enterprise, and WPA2-PSK, this wireless access point provides a secure communication environment to protect sensitive data.
  • Reliable performance
    With a data transfer rate of 1.9 Gbps and support for 802.11ac Wave 2, the device ensures fast and reliable wireless connections, enhancing productivity and user experience.
  • Versatile deployment
    Designed to be ceiling-mountable and wall-mountable, the MR42 Cloud Managed offers flexible installation options to fit various environments and aesthetic preferences.
  • Comprehensive management
    Cloud-managed capabilities allow for easy setup, configuration, and monitoring, simplifying network administration and enabling efficient operation.
Cisco Meraki MR42 Cloud Managed - radio access point - Wi-Fi 5 - cloud-managed
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE+
25.34 cm x 15.58 cm x 3.71 cm
700 g
Radio access point
25.34 cm
15.58 cm
3.71 cm
700 g
External
Wireless
Data Transfer Rate
1.9 Gbps
Line Coding Format
256 QAM
Cloud-Managed
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
Traffic shaping, wall mountable, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Wireless Guest Services, Maximum Ratio Combining (MRC), 3T3R MIMO technology, Network Access Control (NAC), ceiling mountable, Wireless Intrusion Prevention System (WIPS), tagged VLAN, security lock slot (cable lock sold separately), 802.1x authentication, Bluetooth Low Energy Beaconing, Unscheduled Automatic Power Save Delivery (U-APSD), anti-virus protection
Encryption Algorithm
AES, TLS, TTLS, TKIP, WPA, WPA2-PSK, WPA2-Enterprise, WEP
Authentication Method
MS-CHAP v.2, Active Directory, Extensible Authentication Protocol (EAP)
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.3at, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11u
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x 1000Base-T (PoE+) - RJ-45
VCCI, ICES-003, EN55024, CISPR 22, FCC Part 15 B, RSS-102, UL 2043, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, FCC Part 15 E, FCC CFR47 Part 15 C, EN 62311, EN 62479:2010, EN 300 328, EN 50385, EN 301489-17, EN 301 893, CAN/CSA-C22.2 No. 60950-1
PoE+
20 Watt
Limited warranty - advance hardware replacement - lifetime
5 - 95% (non-condensing)
Speed: 1.9Gbps
Protocol: IEEE 802.11n
Protocol: IEEE 802.11ac Wave 2
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Compatibility: PC
Brand: Meraki
Price Range Ex VAT: £500 - £750
