Meraki MR30H Cloud Managed AP
PURCHASE TOGETHER WITH A 1 YEAR LICENCE QL: DVQR
Quicklinx: DV8NWS00 Mfr#: MR30H-HW
  • Bluetooth 4.0
  • IEEE 802.11n
£402.32 ex VAT
£482.78 inc VAT
The Cisco Meraki MR30H is a dual-radio, cloud-managed 2x2:2 802.11ac Wave 2 wall switch access point with MU-MIMO support. Designed for next-generation deployments in hotel rooms, university residences, and other multi-dwelling units, the MR30H provides performance, enterprise-grade security, and simple management.
A dedicated third radio provides real-time WIDS/WIPS with automated RF optimization. Four Ethernet ports on the wall switch allow easy connectivity of external wired devices. An integrated Bluetooth Low Energy (BLE) radio delivers beacon and scanning capabilities.
The combination of cloud management, 802.11ac Wave 2, full-time RF environment scanning, a wall switch and an integrated Bluetooth technology delivers the high throughput, reliability, convenience and flexibility required by demanding business applications.
  • Efficient connectivity
    The Cisco Meraki MR30H Cloud Managed offers seamless integration with Ethernet 10Base-T/100Base-TX/1000Base-T interfaces, including PoE+ support for simplified deployment and reduced cable clutter. Its omnidirectional antenna ensures wide coverage, making it ideal for various environments.
  • Advanced security
    Equipped with multiple encryption algorithms including AES, TKIP, and WPA2-Enterprise, this wireless router provides a secure connection, safeguarding sensitive data. The inclusion of Wireless Intrusion Detection and Prevention Systems further enhances network security, offering peace of mind.
  • High-performance wireless access
    With support for 802.11ac Wave 2, including 2T2R MIMO and MU-MIMO technologies, the device ensures high-speed connectivity and improved network efficiency. Its dual-band capability allows for a more reliable connection by minimizing interference.
  • Comprehensive control and quality
    Features like Quality of Service (QoS) and 802.1x authentication provide granular network control and prioritize traffic, ensuring critical data is transmitted efficiently. The integrated 4-port switch offers additional connectivity options for multiple devices.
Cisco Meraki MR30H Cloud Managed - wireless router - Bluetooth, Wi-Fi 5 - wall-mountable
Wireless router - 4-port switch (integrated)
Enclosure Type
Wall-mountable
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Network / Transport Protocol
IPSec
WIDS, QoS, 2T2R MIMO technology, MRC, WIPS, 802.1x authentication, MU-MIMO technology, beamforming technology, SU-MIMO technology
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11r, IEEE 802.11ac Wave 2
15.5 cm x 11 cm x 2.3 cm
409 g
Australia, Asia, United Kingdom, United States, Europe
Enclosure Type
Wall-mountable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
IPSec
Encryption Algorithm
AES, TLS, TTLS, TKIP, WPA, WPA2-PSK, WPA2-Enterprise, WEP
Authentication Method
MS-CHAP v.2, Extensible Authentication Protocol (EAP)
Status Indicators
Power, status
Line Properties
Line Coding Format
256 QAM
WAN: 1 x 10Base-T/100Base-TX/1000Base-T (PoE+) - RJ-45 , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T (PoE) - RJ-45
Aerial
Aerial
Internal
Directivity
Omni-directional
25 Watt
Security screw, concealed mount plate
Mounting Kit
Included
15.5 cm
11 cm
2.3 cm
409 g
Limited warranty - lifetime
5 - 95% (non-condensing)
Type: Wireless router
Connectivity: Wired
Connectivity: Wireless
Speed: 1.3Gbps
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac Wave 2
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Protocol: Ethernet
Protocol: IEEE 802.11g
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Protocol: Bluetooth 4.0
Brand: Meraki
