Meraki Go is WiFi built for businesses. With Meraki Go, you can easily add multiple WiFi networks so that staff, guests, and point-of-sale devices can share a single internet connection. Set up blocked websites to secure your network, and easily limit usage of certain applications to prioritize your business-critical applications. Each Indoor and Outdoor Access Point requires an active Go subscription, which provides a 1-year hardware warranty, security updates, and in-app support. Within the Meraki Go smartphone app, setup is quick and troubleshooting is easy with Guided Setup and Network Alerts.
QUICK & EASY SETUP
Get your network up and running in minutes. Simple, yet powerful management from anywhere using the Meraki Go mobile app or web portal -
SECURE & RELIABLE
Business-grade security that blocks malicious websites, malware, phishing, and other harmful threats. Stay connected and productive with devices powered by Cisco -
FEATURES FOR BUSINESS
Create guest WiFi with a tap, a custom splash page in seconds, or use guest insights to better engage with customers. Remote visibility, troubleshooting tools, and alerts -
NO FEES OR LICENSES
With no required subscription or license, you'll get automatic updates, mobile app management and tech support included -
MADE FOR OUTDOOR
IP67-rated to withstand tough climates and environments
- Cisco Meraki Go GR60 - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External - outdoor
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
- Frequency Band
- 2.4 GHz, 5 GHz
- Included Accessories
- Mounting screws, mounting kit
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- DC 12 V / DC 37 - 57 V (PoE)
- 24.3 cm x 11.4 cm x 3 cm
- 1-year warranty
- Ruggedized Design
- Outdoor
- 24.3 cm
- 11.4 cm
- 3 cm
- Form Factor
- External
- Connectivity Technology
- Wireless
- Line Coding Format
- 256 QAM
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, Boot State, status
- Maximum Ratio Combining (MRC), beamforming technology, SU-MIMO technology, PMK Caching, 2x2 MU-MIMO technology, layer 3 roaming, opportunistic key caching (OKC), packet aggregation
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Directivity
- Omni-directional
- 1 x 1000Base-T (PoE) - RJ-45
- RoHS, Directive 93/42/EEC, EN 60601-2
- PoE
- Voltage Required
- 11 Watt
- Limited warranty - 1 year
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
