Meraki GO GS110 48port Switch Managed 48x10/100/100 + 2SFP
Quicklinx: FJD7WS00 Mfr#: GS110-48-HW-UK
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
£485.73 ex VAT
£582.87 inc VAT
Meraki Go's cloud-based switches are specially designed with small business owners in mind. Create a complete app-managed network solution to increase business productivity and customer engagement, with minimal time, resources, and expertise.
Get up and running in less than 5 minutes, with no technical knowledge needed. The Meraki Go app will guide you through each step of connecting and configuring your network.
See what devices are connected to which ports without having to physically follow cables, troubleshoot problems using live tools built into the app, for example cable testing, and increase security by disabling unused ports.
Your hardware will be automatically kept up to date with the latest firmware, meaning you don't have to worry about your critical business data being exposed to hackers or ransomware attacks.
  • EASY TO SET-UP AND MANAGE
    Connect devices securely, 24/7 port visibility, and simple cloud management with the Meraki Go mobile app; easily add multiple admins to help manage your networking equipment
  • PEACE OF MIND
    Alerts for connectivity problems and remote troubleshooting tools when needed
  • FEATURES FOR BUSINESSES
    Apply bulk settings to switch ports, VLANs, QoS
  • ALL-INCLUSIVE WITH NO SUBSCRIPTION REQUIRED
    Automatic updates, mobile app management and tech support included; mount and screw kit, GS110-48, QSG, PSU in the box
  • COST EFFECTIVE & SCALABLE
    Easily add ports as your businesses technology needs grow and manage from one place; desktop or wall mountable
Cisco Meraki Go GS110-48 - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x SFP (mini-GBIC) (uplink)
Performance
Switching capacity: 104 Gbps
Fanless, cloud managed
United Kingdom
1-year warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
48 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP uplink , 1 x management RJ-45
United Kingdom
Limited warranty - 1 year
Ports: 48
Managed: Yes
Brand: Meraki GO
