Meraki Go's cloud-based POE switches are specially designed with small business owners in mind. Create a complete app-managed network solution to increase business productivity and customer engagement, with minimal time, resources, and expertise.
Get up and running in less than 5 minutes, with no technical knowledge needed. The Meraki Go app will guide you through each step of connecting and configuring your network.
See what devices are connected to which ports without having to physically follow cables, troubleshoot problems using live tools built into the app, for example cable testing, and increase security by disabling unused ports.
Your hardware will be automatically kept up to date with the latest firmware, meaning you don't have to worry about your critical business data being exposed to hackers or ransomware attacks.
EASY TO SET-UP AND MANAGE
Connect devices securely, 24/7 port visibility, and simple cloud management with the Meraki Go mobile app; easily add multiple admins to help manage your networking equipment -
POWER OVER ETHERNET
24x 1GB PoE | 2x 1GB Uplinks -
PEACE OF MIND
Alerts for connectivity problems and remote troubleshooting tools when needed -
FEATURES FOR BUSINESSES
Apply bulk settings to switch ports, enable/disable PoE on each port, VLANs, QoS -
ALL-INCLUSIVE WITH NO SUBSCRIPTION REQUIRED
Automatic updates, mobile app management and tech support included; mount and screw kit, GS110-24P, QSG, PSU in the box
 - Cisco Meraki Go GS110-24P - switch - 24 ports - Managed - rack-mountable
 - Switch - 24 ports - Managed
- Enclosure Type
 - Rack-mountable 1U
- Subtype
 - Gigabit Ethernet
- Ports
 - 24 x 10/100/1000 (PoE+) + 2 x SFP (mini-GBIC) (uplink)
- Power Over Ethernet (PoE)
 - PoE+
- PoE Budget
 - 195 W
- Performance
 - Switching capacity: 56 Gbps
 - Cloud managed
 - IEEE 802.3at
- Localisation
 - United Kingdom
 - 1-year warranty
- Enclosure Type
 - Desktop, rack-mountable 1U
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE+
- PoE Budget
 - 195 W
- Performance
 - Cloud managed
 - IEEE 802.3at
 - 24 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-X SFP uplink , 1 x management RJ-45
- Localisation
 - United Kingdom
 - Limited warranty - 1 year
