This is the replacement power adapter to be used with the Meraki Go Indoor and Outdoor Access Points in the United Kingdom.
Efficient power supply
Designed for reliability and efficiency, this power adapter ensures your device remains powered up without interruption. Its external form factor makes it easy to connect and use, providing a seamless power supply experience. -
Compact design
The compact and lightweight design of this power adapter makes it an ideal choice for those who need a portable power solution. It's easy to carry and store, perfect for both home and office use.
- Cisco Meraki - power adapter - 12 Watt
- Power adapter - external
- Localisation
- United Kingdom
- Power Capacity
- 12 Watt
- Designed For
- P/N: GR60-HW-US
- Localisation
- United Kingdom
- Power Capacity
- 12 Watt
- Designed For
- P/N: GR60-HW-US
