Meraki GO Go Power adapter for Wifi Access Point
Quicklinx: FJDPWS00 Mfr#: GA-PWR-12W-UK
£20.81 ex VAT
£24.97 inc VAT
This is the replacement power adapter to be used with the Meraki Go Indoor and Outdoor Access Points in the United Kingdom.
  • Efficient power supply
    Designed for reliability and efficiency, this power adapter ensures your device remains powered up without interruption. Its external form factor makes it easy to connect and use, providing a seamless power supply experience.
  • Compact design
    The compact and lightweight design of this power adapter makes it an ideal choice for those who need a portable power solution. It's easy to carry and store, perfect for both home and office use.
Cisco Meraki - power adapter - 12 Watt
Power adapter - external
United Kingdom
Power Capacity
12 Watt
P/N: GR60-HW-US
United Kingdom
Power Capacity
12 Watt
P/N: GR60-HW-US
Brand: Meraki GO
