Meraki Cloud-Managed 8 Port Gigabit Switch
REQUIRES LICENCE. CONTACT OUR IT SPECIALISTS: 0370 429 3010
Quicklinx: 92BDWS00 Mfr#: MS220-8-HW
The Meraki MS220-8 is a next generation 8-port Ethernet access switch, combining the benefits of cloud based centralized management with a powerful, reliable platform. The MS220-8 switch for branch, retail, and distributed networks, is configured and monitored over the web, and can be provisioned and managed without on-site IT, training, or dedicated staff. Each Meraki MS220-8 switch is automatically monitored from the cloud, with continuous testing for cable failures, WAN connectivity, and more. The MS220-8 alerts you to problems via email alerts, and provides rich web-based diagnostics to troubleshoot your network from any browser.
  • Centrally managed from the cloud
    The Cisco Meraki Cloud Networking architecture enables Plug and Play branch deployments and provides centralized visibility and control across any number of distributed locations. The Cisco Meraki MS is the industry's cloud managed switch, combining the benefits of cloud-based centralized management with a powerful, reliable access platform. With cloud management, thousands of switch ports can be configured and monitored instantly, over the web. Provision remote sites without on-site IT, deploy network-wide configuration changes, and easily manage campus and distributed networks without training or dedicated staff.
  • Layer 7 application and client visibility
    Cisco Meraki MS Switches are the industry's only switches featuring integrated Layer 7 application and client fingerprinting and analysis. Hundreds of applications are automatically identified and reported, from business apps to BitTorrent and YouTube, so administrators can see where resources are spent.
  • QoS for voice and video
    Deploy latency-sensitive applications such as voice and video by guaranteeing network performance. Voice and QoS features such as per-VLAN and protocol-based prioritization, as well as flexible QoS assignments, give intuitive, granular control.
  • Enterprise security
    Extending security down to the port level has never been easier. MS Switches integrate seamlessly with enterprise-grade security systems using 802.1x. Define access policies, segregate guest devices, and quarantine entire environments right from the dashboard.
Cisco Meraki Cloud Managed MS220-8 - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x Gigabit SFP
Performance
Switching capacity: 20 Gbps
MAC Address Table Size
8000 entries
Remote Management Protocol
SNMP 2c
DHCP support, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, E-mail alert, Broadcast Storm Control, firmware upgradable, Quality of Service (QoS)
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.1ab (LLDP)
23 cm x 22 cm x 4.4 cm
1.1 kg
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Performance
8000 entries
SNMP 2c
8 x 1000Base-T RJ-45 , 2 x Ethernet 1000 - SFP (mini-GBIC)
Internal power supply
10 Watt
23 cm
22 cm
4.4 cm
1.1 kg
Limited warranty - replacement - lifetime
5 - 95% (non-condensing)
