The Cisco Meraki 12 V AC adapter provides a quick and easy way to power your Cisco Meraki Enterprise access points.
- Cisco Meraki - power adapter
- Power adapter - external
- 110 g
- Localisation
- Europe
- Input Voltage
- AC 100-240 V
- Output Voltage
- 12 V
- 6.9 cm x 6.6 cm x 3 cm
- 1-year warranty
- Designed For
- Cisco Meraki MR12, MR12 Cloud Managed, MR16 Cloud Managed, MR18, MR24 Cloud Managed 3x3 MIMO, MR26 Cloud Managed 3x3 MIMO, MR32 Cloud Managed, MR34
- Localisation
- Europe
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- Output Voltage
- 12 V
- Max Electric Current
- 1.5 A
- Limited warranty - 1 year
- 6.9 cm
- 6.6 cm
- 3 cm
- 110 g
- Designed For
