Matrox P690 256mb PCI-E x16 LP Graphics Card
Quicklinx: 8DD7WS00 Mfr#: P69-MDDE256LAUF
The low-profile Matrox Millennium P690 Plus LP PCIe x16 offers 256MB of graphics memory, full DualHead support for two digital or analog monitors at high resolution and pristine image quality, and can be upgraded (via a Quad-HD15 cable) to drive four analog monitors. With ultra-low power consumption, fanless cooling, and unified display drivers for easy deployment across multiple systems, the P690 Plus LP PCIe x16 is suitable for a wide range of professional applications. This graphics card builds upon the reliability, stability, and features of the proven Millennium P-Series product line, making it an ideal choice for use in long-life environments.
Matrox Millennium P690 Plus LP PCIe x16 - graphics card - MGA P690 - 256 MB
Graphics card - low profile
Bus Type
PCI Express x16
Graphics Engine
Matrox MGA P690
256 MB DDR2
Max Resolution
2046 x 1536
Max Monitors Supported
2
1 x DVI-I - 60 PIN LFH , 2 x DVI-I - 24+5 pin combined DVI (on supplied cable) , 2 x VGA - 15 pin HD D-Sub (HD-15) (with adapter)
16.8 cm x 6.9 cm
3-year warranty
Bus Type
PCI Express x16
Graphics Engine
Matrox MGA P690
Max Resolution
2046 x 1536
2
Size
256 MB
DDR2 SDRAM
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Vista, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions)
Additional Requirements
CD-ROM
Low-profile bracket
1 x DVI cable - 30.5 cm , 2 x DVI-VGA adapter
Software Included
Drivers & Utilities
FCC Class A certified, CSA, VCCI, RoHS, WEEE, ACA
16.8 cm
6.9 cm
Limited warranty - 3 years
