The Matrox Millennium P690 PCI offers 128MB of graphics memory and full DualHead support for using two digital or analog monitors at high resolution and pristine image quality. With ultra-low power consumption, fanless cooling and unified display drivers for easy deployment across multiple systems, the P690 PCI is suitable for a wide range of professional applications. This graphics card builds upon the reliability, stability, and features of the proven Millennium P-Series product line, making it an ideal choice for use in long-life environments.
- Matrox Millennium P690 PCI - graphics card - MGA P690 - 128 MB
- Graphics card
- Bus Type
- PCI
- Graphics Engine
- Matrox MGA P690
- Memory
- 128 MB DDR2
- Max Resolution
- 2048 x 1536
- 2 x DVI-I - 24+5 pin combined DVI , 2 x VGA - 15 pin HD D-Sub (HD-15) (with adapter)
- 16.8 cm x 10.7 cm
- 3-year warranty
- Graphics card
- Bus Type
- PCI
- Graphics Engine
- Matrox MGA P690
- Max Resolution
- 2048 x 1536
- Size
- 128 MB
- Technology
- DDR2 SDRAM
- OS Required
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Vista, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions)
- Cables Included
- 2 x DVI-VGA adapter
- Software Included
- Matrox PowerDesk, Driver
- CSA, VCCI, EMC, FCC, RoHS, WEEE
- 16.8 cm
- 10.7 cm
- Limited warranty - 3 years
