Matrox M9148 1GB PCI-E x16 Low Profile Display Port
Quicklinx: 70BCWS00 Mfr#: M9148-E1024LAF
  • DisplayPort
  • Windows 8 Compatible
The Matrox M9148 LP PCIe x16 four monitor graphics card renders pristine images across four DisplayPort monitors at resolutions up to 2560 x 1600 per output for an exceptional multi-monitor user experience. With 1 GB of memory and advanced desktop management features such extending the Windows Taskbar to span multiple displays and support of independent or stretched modes, the M9148 drives business, industrial, and government applications with extraordinary performance. Its low-profile form factor makes it easy to integrate into a wide variety of systems, it offers optimal Windows Vista Aero support (WDDM mode), and it can be paired with another M9148 graphics card to support up to eight DisplayPort monitors from a single system.
  • High-resolution four DisplayPort monitor support
    It is up to 2560 x 1600 per output.
  • Native PCI express x16 performance
    It is maximum bandwidth to ensure best performance.
  • 1 GB of memory
    For enhanced performance in demanding multi-monitor applications.
  • Low-profile form factor
    To fit in a wide variety of systems; includes bracket for full-height ATX form factor.
  • Passive cooling and low power consumption
    Fanless design eliminates noise and increases product reliability.
  • Joined graphics card mode
    Insert two M-series cards into the same system to drive even more monitors.
  • Wide enterprise flexibility
    It is unified driver package compatible with other Matrox products.
Matrox M9148 - graphics card - M9148 - 1 GB
Graphics card - low profile
Bus Type
PCI Express x16
Graphics Engine
Matrox M9148
1 GB
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 1920 x 1200 / DisplayPort: 2560 x 1600
Max Monitors Supported
4
Interfaces Details
4 x Mini DisplayPort , 4 x DisplayPort - with adapter , 4 x DVI-D (dual link) - with adapter
API Supported
OpenGL 2.0
16.8 cm 6.9 cm
Microsoft Certification
3-year warranty
Bus Type
PCI Express x16
Graphics Engine
Matrox M9148
Max Resolution
2560 x 1600
4
Interfaces Details
API Supported
OpenGL 2.0
Fanless heatsink
Size
1 GB
Linux, Microsoft Windows Server 2003, Microsoft Windows Vista (32/64 bits), Microsoft Windows Embedded Standard 7, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits)
Low-profile bracket
Software Included
Matrox PowerDesk
This product has been tested to meet all of the technical requirements to be Windows 8 Compatible.
RoHS, WEEE
16.8 cm
6.9 cm
Limited warranty - 3 years
