The Manta 42-inch Passive 3D Widescreen LCD TV supplied with 4 Sets of 3D Glasses (1 are clip-on) brings you the experience of 3D Cinema in your own home.
Connect to either a 3D Blu Ray Player,3D Games Console,Sky+ or Virgin HD+ 3D device to enjoy the full experience of 3D TV (sold separately).
The Manta 42-inch also features 2D to 3D conversion to deliver a pseudo 3D experience via standard Freeview Digital TV or DVD/ Blu Ray. The Manta 42-inch is Full HD1080P compatible ideal for getting the best out of a High Definition Blu Ray player, Full HD games console or other HD device.
Features up to 50 digital Freeview channels & up to 24 radio stations without the need for subscription.
The Manta LCD TV range features a PC input which enables you to connect your PC & use as a PC monitor.
The Manta 42-inch is VESA wall mounting compatible.
This LCD TV features built-in USB Playback facility which enables you to play compatible Photo's, Music & Video (including 3D) content saved onto an external USB Stick (sold separately).
Manta TV's come with a Power Supply Switch for safe power cut-off to save energy.
Manta LCD TV's feature easily accessible side connections for USB,Headphone,S-Video & AV Inputs.
Box Contains
Manta LCD4214 42" 3D LCD TV, 4 Pairs of Passive 3D Glasses (1 are clip-on), TV Stand, Remote Control & Batteries, Instructions
- Model
- LCDTV4214
- HD Standard
- 1080p (FullHD)
- Display / Diagonal Size
- 42 in
- Television / Type
- 3D LCD TV
- Technology
- LCD
- Display / 3D Technology
- Native Resolution
- 1,920 x 1,080
- Aspect Ratio
- 16:9
- Video Input / Analogue Video Format
- PAL
- Freeview Bult In
- Freeview
- TV Tuner / Type
- DVB-T
- Tuner Type
- 1x digital
- HDMI Inputs
- 2
- Interface
- SCART, Composite, Component, S-Video
- Contrast Ratio
- 15,000:1
- Dimensions & Weight / Depth
- 115 mm
- Dimensions & Weight / Height
- 625 mm
- Dimensions & Weight / Width
- 1014 mm
- Television / Diagonal Size (cm)
- 106.7 cm
- Audio System / Speaker System
- 2 speakers
- Dimensions & Weight (Shipping) / Shipping Weight
- 22 kg
- Display / Image Aspect Ratio
- 16:9
- Display / Image Contrast Ratio
- 15,000:1
- Display / Interface
- VGA (HD-15)
- Display / Widescreen
- Widescreen
- Memory Card Reader / USB Port
- Memory Card Reader / USB Ports Qty
- 1
- Network & Internet Multimedia / Connectivity Protocols
- USB
- Network & Internet Multimedia / Functionality
- Digital video playback
- Stands & Mounts / Stand Included
- Video Input / Analogue video Signal
- Scart
- TV Tuner / Tuner Qty
- 1
- Digital TV Tuner / Digital TV Tuner Type
- DVB-T
- TV Tuner / Conditional Access
- Common Interface (CI) slot
