Manhattan Universal Flat-Panel TV Articulating Wall Mount
Quicklinx: 9PQ1WS00 Mfr#: 423748
Overcome odd floor plans, annoying glare and awkward furniture placements that can diminish flat-panel TV experiences. Manhattan universal flat-panel TV tilting wall mounts with smooth, one-touch tilt adjustments help keep images, contrasts and colors clear, sharp and defined. VESA-compliant and constructed of quality materials, Manhattan universal flat-panel TV tilting wall mounts fit a variety of display sizes with a secure and confident above-the-floor installation. Ideal for residential, office, hospitality, classroom and conference room, digital signage and other commercial applications, Manhattan universal flat-panel TV tilting wall mounts bring high-performance LCD TV enjoyment front and center.
Manhattan Universal Flat-Panel TV Articulating Wall Mount - wall mount
Wall mount
Adjustable Depth
8-25 cm
Adjustments
Tilt
Recommended Use
LCD / plasma panel
Recommended Display Size
23"-42"
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
20 kg
Material
Aluminium
Adjustable Depth
8-25 cm
Material
Aluminium
AV Furniture
Wall mount
Mounting Components
Tilt/swivel wall mount
Recommended Use
LCD / plasma panel
23"-42"
Adjustments
Tilt
Max Load Weight
20 kg
Swivel adjustment
Limited warranty - lifetime
