Manhattan Dual Port Serial PCI Express Card
Quicklinx: BWKKWS00 Mfr#: 158169
PCI Express Balances Cost, Performance, Compatibility and Advanced Features for Computing Platforms The MANHATTAN Serial PCI Express Card quickly and easily adds one DB9 port to PCI Express-enabled desktop systems to connect and communicate with serial peripheral devices.
Fast Data Transfer
The MANHATTAN Serial PCI Express Card can be configured to achieve baud rates of up to 230,400 bps to take advantage of PCI Express data transfer speeds of up to 2.5 Gbps. Compliance with PCI Express 1.1 specifications ensures that most PCI ExpressCard-equipped desktop computers and devices can operate at peak performance.
Simple Installation
The MANHATTAN Serial PCI Express Card fits PCI Express x1, x2, x4, x8 and x16 lane buses, and configurable COM port settings provide a flexible way to customize its use to various needs.
  • Easily adds two configurable serial ports to a desktop computer.
  • Fits PCI Express x1, x2, x4, x8 and x16 lane buses.
  • Fits standard and low-profile PCI slots.
  • Plug and Play installation; hot-swappable — Windows compatible.
  • PCI Express balances cost, performance, compatibility and advanced features for computing platforms
  • Fast Data Transfer
  • Simple installation
Manhattan Serial PCI Express Card - serial adapter - PCIe - RS-232 x 2
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
RS-232 x 2
Serial
Microsoft Windows Server 2003, Microsoft Windows 2000/XP/Vista/7
Serial adapter
Plug-in card
PCI Express x1
Ports
RS-232 x 2
Wired
Serial
2 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express
Plug and Play
Software Included
Driver
Additional Requirements
CD-ROM
Limited warranty - lifetime
