Bluetooth
Experience superior audio using powerful sound. Simply pair and play, begin streaming from your favourite music apps including Spotify and Soundcloud or radio stations. If your Smart TV has Bluetooth, you can also use the Snowdon II as a Bluetooth soundbar for TVs to create an effective and discreet TV sound system.
Stereo Speaker
With 2.1 Channel Sound, the Snowdon II offers a superior audio experience for any home theatre set-up.
Multi-Connection
The Snowdon II boasts a wide range of connectivity including Bluetooth, Optical input, RCA, and AUX-input. The Snowdon II comes with an RCA cable. Designed for the eager audiophile, you can select which mode you want to listen to: Music, Movies or Dialogue.
Built-In Subwoofer
Delivering high definition sound, the Bluetooth stereo speakers fill the room with your favourite sounds using the provided remote control.
Bluetooth, built-in subwoofer
What sets this powerful soundbar apart is its built-in subwoofer, delivering earth-shaking bass, making every note come alive. Delve into an extraordinary auditory odyssey, effortlessly connecting your devices via Bluetooth. -
120 W, 2.1 stereo sound
Experience audio supremacy with its 120 W power, boasting captivating 2.1 stereo sound. Elevate your entertainment to cinematic levels, where every nuance is delivered with extraordinary clarity and breath-taking depth. -
Multi-connection
Offering multi-connection capabilities, allowing you to seamlessly link and transition between a myriad of devices. AUX, optical and RCA. Immerse yourself in a dynamic sound experience, perfectly attuned to your lifestyle. -
Wall-mountable
Unleash cinematic brilliance with this sleek soundbar. Wall-mountable for a stylish fit, it brings big-screen audio to your living space. Elevate your entertainment in a world of vivid sound and visuals.
- Majority Snowdon - sound bar - for TV - wireless
- Product Type
- Sound bar - for TV - 2.1-channel
- Speaker Type
- Active
- Continuous Power
- 120 Watt
- Frequency Response
- 30 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- MP3
- Speaker Details
- Sound bar - stereo x 2 - active , Sound bar - subwoofer - active
- White
- 81 cm x 8.3 cm x 8.3 cm
- 1.5 kg
- 3-year warranty with product registration
- Product Type
- Enclosure Colour
- White
Speaker System
- Speaker Type
- Active
- Continuous Power
- 120 Watt
- 30 - 20000 Hz
- Signal-To-Noise Ratio
- 70 dB
- Amplifier
- Integrated
- Bluetooth 5.0
- Audio Formats
- MP3
- Controls
- Power on/off, volume, sources switch
Speaker System Details
- Speaker Details
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2) , Digital audio input (optical) (TOS Link)
- Included Accessories
- AC power adaptor, remote control, 3.5 mm to 3.5 mm cable, RCA cable
- Power Source
- AC power adapter
- 81 cm
- 8.3 cm
- 8.3 cm
- 1.5 kg
- Limited warranty - 3 years
