Crystal Clear Sound Quality
The K2 soundbar and subwoofer is designed right here in the UK by our group of audio experts. The Majority K2 is a powerful TV sound bar with wireless subwoofer, packed with the latest audio technology and compatible with a wide range of household items such as your phone, TV, PC, laptop, projector, monitor, Blu-Ray or DVD player. Our enhanced digital sound quality is designed and perfected in Cambridge UK.
Powerful Speakers and Subwoofer
The K2 soundbar with wireless subwoofer is a 2.1 stereo surround sound system which delivers an outstanding cinematic audio experience. The powerful 150 watt speakers can pack a punch for any avid gamer or simply enhance your TV experience with clean and crisp audio. Music, radio, gaming, movies, live sport, tv shows - listen to audio the way its meant to be heard with the Majority K2 Sound bar.
Packed Full of Features
Our soundbar and subwoofer has been designed with ease of use in mind - simply plug in, and play using the wide range of connections. Connect to your TV in lightning speed by using the HDMI ARC or optical input for high clarity and rich audio. Listen to your playlists straight from your phone through the latest Bluetooth technology, plug in your MP3 player to the AUX or USB input.
High Definition Audio
The K2 soundbar is a slim audio sound bar with a wireless subwoofer that fits perfectly under your TV or on a desk. Use the buttons on the side of the soundbar or the supplied remote to go truly wireless and adjust the volume, equaliser settings, source and much more. An ideal sound bar for TV or PC, fill your room and immerse yourself with high definition sound in your very own home.
                Versatile connectivityWith a wide range of connections including 4-pin USB Type-A, mini-phone stereo 3.5 mm, 19-pin HDMI Type-A, RCA for subwoofer output, and TOSLINK for SPDIF input, this sound bar system offers versatile connectivity options for all your audio needs.
                Wireless freedomEnjoy the convenience of wireless audio streaming with Bluetooth connectivity. This feature allows you to connect your devices wirelessly, ensuring a clean and clutter-free setup.
                Enhanced audio experienceThe Majority K2 sound bar system is designed to enhance your audio experience with its 2.1-channel speaker system configuration, including an integrated sound bar and subwoofer. Experience deep bass and clear highs for an immersive listening experience.
- Majority K2 - sound bar system - for TV - wireless
- Product Type
- Sound bar system - for TV - 2.1-channel
- Media Content Source
- USB-host
- FM radio
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 150 Watt
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- MP3, WMA, WAV, FLAC, AAC +
- Speaker System Details
- 1 x sound bar , 1 x subwoofer
- Black
- 4.9 kg
- 3-year warranty with product registration
- Product Type
- FM radio
- USB-host
- Enclosure Colour
- Black
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 150 Watt
- Amplifier
- Integrated
- Audio Return Channel (ARC) Capability
- Bluetooth
- Audio Formats
- Speakers Included
- 1 x sound bar , 1 x subwoofer - wireless
- Connector Type
- USB (4 PIN USB Type A) , Audio line-in (mini-phone stereo 3.5 mm) , HDMI (19 pin HDMI Type A) , Subwoofer output (RCA) , SPDIF input (TOS Link)
- Included Accessories
- Remote control, 3.5 mm to 3.5 mm cable, HDMI cable, 2 AC power adapters
- 4.9 kg
- Dimensions (WxDxH) / Weight Details
- Sound bar: 76.2 cm x 6.9 cm x 5.5 cm , Subwoofer: 19.7 cm x 19.7 cm x 28 cm
- Shipping Width
- 23 cm
- Shipping Depth
- 80 cm
- Shipping Height
- 35 cm
- Shipping Weight
- 5.2 kg
- Limited warranty - 1 year , Limited warranty - 3 years - after registration
