Majority Everest 300W 5.1 Dolby Audio Soundbar with Wireless Sub
Quicklinx: HRB3WS00 Mfr#: 1000002689
Audio System Type: Soundbar system
Surround system: [N/A]
Hurry, only 1 left in stock!
£208.33 ex VAT
£249.99 inc VAT
Powered by Dolby Audio, the Everest delivers state-of-the-art sound to transform any and every home theatre. Offering cinematic experience and deep immersive bass, sound acts as a storyteller, appearing at various positions in the room.
  • Surround sound
    Define surround sound when you fill the room with the Majority Everest 300-Watt Bluetooth 5.1 Surround Sound System with Dolby Audio, wireless subwoofer and rechargeable wireless detachable satellite speakers.
  • Subwoofer
    With a 5.25-inch driver, the booming subwoofer blends seamlessly with the speakers to unleash the powerful bass. From console gaming to weekend-long film binges, plus live broadcasts of musical performances, fill the room with every nail-biting and note-hitting moment at maximum capacity for supreme entertainment.
  • Detachable satellite speakers
    Pump up the party and feel the sound vibrating in your furniture using the Everest s superior sound system. Enjoy audio as you see fit using the detachable satellite speakers. The 16.8cm rechargeable speakers with a built-in battery will keep you thoroughly entertained with up to 8 hours of playback of clear and crisp audio. The compact size makes them ideal for any home entertainment set-up, be it gaming or home cinema.
  • Sound modes
    Offering a deep immersive bass and the option to cater your listening to your entertainment, the Everest is the ultimate audio experience.
  • Connections
    The Everest connects via HDMI, Bluetooth, optical, AUX port and USB for non-stop audio enjoyment.
Majority Everest - sound bar system - wireless
Sound bar system - 5.1-channel
Media Content Source
USB-host
System Components
2 speakers, subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
300 Watt
Amplifier
Integrated
Bluetooth
Audio Formats
MP3
Speaker System Details
1 x sound bar , 1 x subwoofer , 2 x satellite speaker
Built-in Decoders
Dolby Audio
Sound Effects
3D surround sound
5.7 kg
3-year warranty
USB-host
Enclosure Material
Plastic, PVC, wood
Design Features
Detachable wireless battery-powered rear channel speakers
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
300 Watt
Amplifier
Integrated
Sound Effects
3D surround sound
Bluetooth
Built-in Decoders
Dolby Audio
Audio Formats
MP3
Speakers Included
1 x sound bar , 1 x subwoofer - wireless , 2 x satellite speaker - wireless
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 5.25"
Connector Type
Audio line-in , HDMI (19 pin HDMI Type A) , Digital audio input (optical) (TOS Link) , USB (4 PIN USB Type A)
Audio cable, remote control
5.7 kg
Dimensions (WxDxH) / Weight Details
Sound bar: 9.83 cm x 90 cm x 6.56 cm / 2 kg , Subwoofer: 20 cm x 20 cm x 25 cm / 3.3 kg , Satellite speaker: 9.83 cm x 6.56 cm x 16.8 cm / 400 g
Limited warranty - 3 years
Brand: Majority
