Subwoofer, 100 Watts, 2:1 Stereo
Enhance your audio experience with our 2.1 stereo sound bars for tv featuring a powerful 100-watt subwoofer. Elevate your tv surround sound system with deep bass and well-balanced audio that fills the room.
Bluetooth, EQ, Remote
The integrated Bluetooth functionality facilitates effortless pairing with Bluetooth-enabled devices. Seize total control over your tv sound bar audio with the included remote, enabling seamless volume and EQ controls.
AUX, USB, Optical, RCA
Enjoy music, movies, and more directly from your USB drive. Immerse in premium sound by linking your TV and Bowfell Plus tv sound system via Optical input. Effortlessly connect smartphones and audio gadgets via the Aux input for a superior audio experience.
PC, TV, Projector, Surround Sound
Meticulously engineered, this feature-rich soundbar transforms into a home cinema sound system, immersing you in unparalleled cinematic, musical, and gaming brilliance. Perfect sound bar with subwoofer for tv, pc and laptops.
Long throw subwoofer for room-filling audio
This high-performing 2.1 speaker system produces 100W peak power. Paired with a long throw dedicated subwoofer for enhanced bass, the Majority Bowfell Plus is capable of deep, thumping bass that will transport you to the world of your entertainment and captivate the experience no matter the room size. -
Crystal-clear sound quality
The Bowfell Plus sound bar is designed in the UK by the group of audio experts. The Majority Bowfell Plus is a powerful TV sound bar packed with a modern audio technology and compatible with a wide range of household items such as your phone, TV, PC, laptop, projector, monitor, Blu-Ray or DVD player. The enhanced digital sound quality is designed and perfected in Cambridge UK. -
Packed full of features
The Majority sound bar has been designed with ease of use in mind - simply plug in, and play using the wide range of connections. Connect to your TV in lightning speed by using the optical input, listen to your playlists straight from your phone through the Bluetooth technology, plug in your MP3 player to the AUX input, or just plug in your USB device straight into the Bowfell.
- Majority Bowfell Plus - sound bar - wireless
- Product Type
- Sound bar
- Media Content Source
- USB-host
- Speaker Type
- Active
- Nominal Output Power (Total)
- 100 watt
- Amplifier
- Integrated
- Bluetooth
- Speaker Details
- Sound bar - stereo - active , Sound bar - subwoofer - active
- Black
- Power
- 12 V
- 38.8 cm x 5.43 cm x 7.21 cm
- 1.5 kg
- 1-year warranty
- Product Type
- Sound bar
- USB-host
- Enclosure Colour
- Black
Speaker System
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 100 watt
- Amplifier
- Integrated
- Bluetooth
- Controls
- Power on/off, volume
Speaker System Details
- Speaker Details
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , USB (4 PIN USB Type A) , Digital audio input (optical) (TOS Link)
- Included Accessories
- AC power adaptor, remote control, 3.5 mm to 3.5 mm cable, 3.5 mm to RCAx2 cable
- Power Source
- AC power adapter
- Voltage Required
- 12 V
- 38.8 cm
- 5.43 cm
- 7.21 cm
- 1.5 kg
- Dimensions (WxDxH) / Weight Details
- Sound bar: 38.8 cm x 5.43 cm x 7.21 cm / 1.5 kg , Subwoofer: 9 cm x 22.4 cm x 30.8 cm
- Limited warranty - 1 year , Limited warranty - 3 years with product registration
